GoNz0's avatar
GoNz0
Dialled in
10 months ago
Lots of pre and post errors, dropouts etc, T3 timeouts, too many errors to put in the title
Can one of the staff please arrange to get the network checked and an engineer out, I've no idea if this is another cable from box to house error as it's been a few since you last ran new to the box but I get the feeling it's in the box up the road or from there back.
Power levels are ok but we are facing drop outs throughout the day, I'm having to reboot the hub 2-3 times a week to get things stable again.
Various logged errors
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=
TLV-11 - unrecognized OID;CM-MAC=
16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-
No Ranging Response received - T3 time-out;CM-
SYNC Timing Synchronization failure - Loss of Sync
Most of the above repeat over and over looking at the logs. It's no longer stable and causing issues working from home.
Thanks.
  • Tudor's avatar
    Please post full set of stats, details follow:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
    • Topgun's avatar
      Topgun
      Dialled in
      Apologies if I'm hijacking this thread but I seem to be having issues with small drop outs regularly. Could someone please check this  for me please? I have 1 gig through my Hub 4, which is in modem mode connected to my Synology router.
      Thanks.
      3.0 Downstream channels
      253307500004.140.9QAM25625
      11387500006.639QAM2561
      21467500006.440.4QAM2562
      31547500006.340.4QAM2563
      41627500006.340.9QAM2564
      51707500006.240.9QAM2565
      61787500006.240.4QAM2566
      71867500006.140.9QAM2567
      81947500005.840.4QAM2568
      92027500005.740.4QAM2569
      102107500005.640.9QAM25610
      112187500005.640.4QAM25611
      122267500005.440.4QAM25612
      132347500005.140.4QAM25613
      14242750000540.4QAM25614
      15250750000540.4QAM25615
      16258750000540.4QAM25616
      172667500004.940.4QAM25617
      182747500005.240.4QAM25618
      192827500005.440.4QAM25619
      202907500005.440.9QAM25620
      212987500005.140.4QAM25621
      223067500004.740.4QAM25622
      233147500004.540.4QAM25623
      243227500004.340.4QAM25624
      263387500004.140.4QAM25626
      273467500004.240.4QAM25627
      283547500004.140.4QAM25628
      29362750000440.4QAM25629
      303707500003.940.4QAM25630
      313787500003.740.4QAM25631
      323867500003.840.4QAM25632
      25Locked40.94620900
      1Locked38.98326100
      2Locked40.36628700
      3Locked40.36628700
      4Locked40.94620900
      5Locked40.94620900
      6Locked40.36628700
      7Locked40.94620900
      8Locked40.36628700
      9Locked40.36628700
      10Locked40.94620900
      11Locked40.36628700
      12Locked40.36628700
      13Locked40.36628700
      14Locked40.36628700
      15Locked40.36628700
      16Locked40.36628700
      17Locked40.36628700
      18Locked40.36628700
      19Locked40.36628700
      20Locked40.94620900
      21Locked40.36628700
      22Locked40.36628700
      23Locked40.36628700
      24Locked40.36628700
      26Locked40.36628700
      27Locked40.36628700
      28Locked40.36628700
      29Locked40.36628700
      30Locked40.36628700
      31Locked40.36628700
      32Locked40.36628700
      3.1 Downstream channels
      159944K1800QAM4096424
      159Locked424.440882321670
      • Topgun's avatar
        Topgun
        Dialled in
        3.0 Upstream channels
        13010000040.35120 KSym/secQAM644
        22360000039.85120 KSym/secQAM645
        33660000040.85120 KSym/secQAM643
        44310000041.35120 KSym/secQAM642
        54960000041.85120 KSym/secQAM641
        3ATDMA0000
        4ATDMA0000
        5ATDMA0000
        3.1 Upstream channels
        610.045.02KQAM128
        6OFDMA20053.900
  • Sephiroth's avatar
    Sephiroth
    The reason that forum members ask for the stats, despite your calling on VM staff to assist, is that we members can provide insights for you that will never be disclosed by the VM bods.  There are many instances on here where our diagnostics have proved to be correct notwithstanding the “nothing wrong” words from VM staff on the phone or in the forum.
    The VM bods would look at current status of your hub but would be unlikely to catch the stats during an event.  So do please capture your stats when things go wrong.
    Keep us posted.
    Sephiroth
    In the absence of any report about a wired connection, we can assume for now that there is a WiFi issue and that your circuit is behaving correctly.
    Do you have "Intelligent WiFi" or "Smart WiFi" or similar setting ON?  If so, does the problem disappear if you disable this useless setting (which causes glitches when the Hub switches to a different channel)?  Also when you turn this OFF (pls do that anyway) set your 2.4GHz channel fixed to any of 1, 6 or 11 which, though contended with neighbours, are not overlapping channels.
    We could also look at how far away are those devices from the Hub?  Could the WiFi signal be if-ish which would trigger automatic channel changes?  Are these 2.4GHz or 5GHz devices?
    Also, do make sure that the CONNECT app is not running on any of your mobile devices - it takes control of your WiFi settings and only gives you grief.
    Keep us posted.
    • Topgun's avatar
      Topgun
      Dialled in
      My set up is as follows, I have 1gig through my Hub 4, that is in modem mode and feeds my Synology RT2600AC router. Because my hub and router are in a far corner of the house, I have had an ethernet cable run to the opposite far corner of the house, where I have a Synology MR2200AC in a mesh set up with my main router.
      This has served me very well for the last few years, except for recently when I've had the issues described. I haven't changed any settings at all, as far as I'm aware. When I do a speed check on my iPad at the far corner of the house away from the main router, I get a solid 550-600 download speed.
      • Topgun's avatar
        Topgun
        Dialled in
        Would the channel change issue be relevant, as I'm in modem mode?
    Sephiroth
    No - the channel change issue is not relevant in modem mode - on the assumption that your router doesn't have comparable auto-channel-switch settings.
    So that brings us back to the 2.4GHz question.  Given that we're talking about a remote part of your house, served with an Ethernet backhaul to your main router, neighbour's 2.4GHz interference is less likely.
    Are you in a position to do stuff wired in the remote location and report?
    • Topgun's avatar
      Topgun
      Dialled in
      So, coming off the Ethernet cable to the back of the house, is a switch, from which I have my TV, 360 box and X box all wired to. I have no issues at all with any of those. The download spread to the X box is very quick and solid.
    Sephiroth
    Do the drop-outs occur when your switch is handling downloads? Remember, the WiFi is also being backhauled down the cable.
    Otherwise, we're down to WiFi behaviour.  What is the WiFI being used for when the glitches occur?
    • Topgun's avatar
      Topgun
      Dialled in
      The switch seems to work fine. It's steady when even doing large downloads to the Xbox. The dropouts all seem to be short and all do do with apps running, Spotify, my house alarm, the printer, Hive occasionally, all sorts of things like that. They'll just not respond for a minute and then burst back into life. TBH it's not the end of the world, just slightly irritating on occasion. I feel my 1 gig connection should be more than enough for everything in the house to run easily, there's only myself and my wife. Although she works from home and is constantly on Zoom, I wouldn't have thought that just the two of us would be maxing out our connection!
    Sephiroth
    You're right.  You aren't maxing your connection out, particularly when not doing downloads.  If you want this bottoming out, you'll need to experiment and report.  For example, when WiFi drops for a minute or so, get onto a wired device at the remote end and see if that's dropped as well.  Then do the same with a wired device at the Hub end.  Process of elimination.
    I know I wouldn't want this happening during a video call.
    13310000001.540QAM 25625
    21390000000.539QAM 2561
    31470000000.439QAM 2562
    41550000000.339QAM 2563
    51630000000.239QAM 2564
    61710000000.239QAM 2565
    71790000000.139QAM 2566
    82590000000.338QAM 25616
    92670000000.138QAM 25617
    102750000000.237QAM 25618
    112830000000.639QAM 25619
    122910000000.939QAM 25620
    132990000001.140QAM 25621
    143070000001.340QAM 25622
    153150000001.440QAM 25623
    163230000001.540QAM 25624
    173390000001.740QAM 25626
    183470000001.640QAM 25627
    193550000001.540QAM 25628
    203630000001.440QAM 25629
    21371000000140QAM 25630
    223790000000.640QAM 25631
    233870000000.340QAM 25632
    243950000000.340QAM 25633
    254030000000.440QAM 25634
    264110000000.540QAM 25635
    274190000000.540QAM 25636
    285230000000.540QAM 25637
    295310000000.440QAM 25638
    305390000000.440QAM 25639
    315470000000.440QAM 25640
    1Locked4080
    2Locked3980
    3Locked3970
    4Locked3990
    5Locked3960
    6Locked3990
    7Locked3990
    8Locked3840
    9Locked3890
    10Locked3750
    11Locked3950
    12Locked3990
    13Locked4080
    14Locked40120
    15Locked4030
    16Locked40140
    17Locked40100
    18Locked40100
    19Locked4050
    20Locked4020
    21Locked4030
    22Locked4040
    23Locked40100
    24Locked4050
    25Locked4060
    26Locked4070
    27Locked4070
    28Locked4060
    29Locked4080
    30Locked4020
    31Locked40100
    41944K1840QAM 40961108
    41Locked39-2.114693263740
    Router status
    Refresh data
    049600000515120QAM 641
    14310000051.35120QAM 642
    23660000051.55120QAM 643
    330100000525120QAM 644
    423600000535120QAM 645
    0ATDMA0000
    3ATDMA0000
    4ATDMA0000
    610.446.52KQAM 256
    6OFDMA2087400000000
      Sephiroth
      @G0Nz0 - as you might have understood, your upstream is struggling.  The stats managed to capture the condition where the VM end cannot read what your Hub is sending in response to the keep-alive requests that it sends to the Hub.  When that happens, the VM end commands a step up in upstream power from your Hub in the hope that it can then read the data.  When it reached 51dBmv, the Hub is maxed out for upstream power and the VM end commands a reset  - a T4 event (not shown in the stats).   So presumably, the VM end can read what the Hub sends when it's at full power.
      I'll bet that all your dropouts occur when the upstream power is maxed and a T4 reset occurs.  This will definitely need a tech and you should hope that the tech can see this issue - your earlier stats showed nothing wrong.
      • GoNz0's avatar
        GoNz0
        Dialled in
        Thanks for the reply, oh well, here we go again. It's been a couple of years since the last load of issues. I thought I was doing well.
    Router status
    Refresh data
    18-09-2024 00:49:35noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-09-2024 00:47:52noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-09-2024 00:42:49noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-09-2024 00:31:09noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    18-09-2024 00:26:06noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 23:26:30noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 23:21:27noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 10:05:28noticeGUI Login Status - Login Success from LAN interface
    17-09-2024 10:05:09noticeGUI Login Status - Login Fail from LAN interface
    17-09-2024 10:04:19noticeREGISTRATION COMPLETE - Waiting for Operational status
    17-09-2024 10:04:15noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 10:04:09noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 10:04:06noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 10:04:03warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 10:04:01noticeHonoring MDD; IP provisioning mode = IPv4
    17-09-2024 10:03:41criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    17-09-2024 10:03:38criticalCable Modem Reboot because of - Reboot UI
    03-09-2024 20:08:50criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-09-2024 20:08:48criticalCable Modem Reboot because of - Reboot UI
    03-09-2024 16:15:05critical16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-09-2024 16:15:05criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    03-09-2024 16:13:57criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    02-09-2024 06:37:09criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    30-08-2024 18:04:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:14criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:13criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:11criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:11criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:09criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:09criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:06criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:05criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    28-08-2024 12:11:03criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
    Log out Language
  • Thanks, hope that's everything you need for now, appreciate the help.
    Needless to say, since rebooting yesterday it's now had an issue as the lack of uncorrectable errors shows.
