Loss of 2.4 ghz WiFi
Bob_TheBaldie
Hi , i was wondering if anybody was having the same issue as me.
Last Sunday i discovered my Hub 3 wasn’t transmitting a 2.4ghz signal . After trying to fix it myself , i phoned Virginmedia . After a lengthy conversation and trying various things, a pin hole reset sorted my problem.
This week , the same again , no 2.4ghz signal. Tried a pin hole reset , still didn’t work.Rang virgin and got though to a call centre in a far off land . To my surprise, after recent interactions haven’t been so good , the young lady i was dealing with got straight to it. She sent out an update and after another reset , all was well again .
why is this happening, do they do updates overnight on a Saturday?
i won’t be happy if it happens again next week.
in the meantime , they’ve offered me a new router as my Hub 3 is 6 years old.
apart from the last 2 weeks , it’s worked well. I’m inclined to  think its their system and not necessarily my router.
Are the newer routers any good?
the last time i agreed to an upgrade i got a TV 360 box and i regretted it ever since .
5 REPLIES 5
Hosay299
Fibre optic
Hi what router have they said u would get ??
i have just joined the tv side and so far it fine
Daniel_Et
Hi @Bob_TheBaldie, thank you for your post.
We're sorry to hear about the problem you've been experiencing 😔
How have things been since you posted? Also, have you tried following all the suggestions provided in this thread here
Regards,
Daniel
Hi Daniel
its been ok so far , but it only seems to happen on Sunday mornings .
customer services are ringing me this Sunday to check everything is running ok. Which i thought was nice .
ive looked at the thread.  I think I’ve tried most of the suggestions . My 2.4 ghz network was saying it was enabled , but a WiFi analyser APP showed it wasn’t . When i disabled it and then tried to re- enable it would throw up an error . Hopefully the update that was sent last Sunday has sorted it .
They haven’t told me which one they’d send.
that’s why i asked if the  routers/hubs are any good . Then i know which one to avoid .
Hi Bob_TheBaldie,
Thanks for coming back and updating us on things.
We're glad things seem to be working for now although I suppose Sunday will be the true test. Keep us posted on how things go and update the thread then 🙂
Kath_P
