on 23-02-2024 00:15
I'm using M250 Virgin media broadband and it is ok for media consumption (e.g. YouTube/Netflix), but it has been unusable for either video calls or games. Both Video calls and games get random freezes. I suspected it was latency spikes and set up BQM which both confirmed it and to be honest, surprised me with the scale of the problem on some days.
Just some of the days within the last week:
I originally thought I must have a cabling issue for the internet to be that unusable, but I had a Virgin technician visiting who confirmed that there are no cabling, signal or hardware issues on my side. He even checked my cable up to the Virgin cabinet.
Can anything be done about this?
23-02-2024 15:28 - edited 23-02-2024 15:28
Just for clarity... are your connection issues happening at the same times on both wifi and ethernet cable connected devices ? What Hub model is it? If Hub5 - is it a 5x?
Can we see the Hub data and see if there is something amiss that the Tech may have missed or appeared after their visit.
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 23-02-2024 22:11
The hub is Hub5 (not 5x).
I see the issues on all devices - ethernet and wifi at the same time. I used to have Virgin Hub in Modem mode, and my router and switch (TP-Link Omada), but when the issues started, I disabled the Modem mode to be able to pinpoint the exact problem in the whole setup. So BMQ is directly to Hub5 in router mode and I do see the same issues when wired directly to Virgin Hub.
The data:
3.0 Downstream channels
1 | 290000000 | 7.4 | 40 | QAM 256 | 20 |
2 | 138000000 | 7.6 | 40 | QAM 256 | 1 |
3 | 146000000 | 7.3 | 40 | QAM 256 | 2 |
4 | 154000000 | 7.1 | 40 | QAM 256 | 3 |
5 | 162000000 | 7 | 40 | QAM 256 | 4 |
6 | 170000000 | 7 | 40 | QAM 256 | 5 |
7 | 178000000 | 7.2 | 40 | QAM 256 | 6 |
8 | 186000000 | 7.4 | 40 | QAM 256 | 7 |
9 | 194000000 | 7.5 | 40 | QAM 256 | 8 |
10 | 202000000 | 7.6 | 40 | QAM 256 | 9 |
11 | 210000000 | 7.9 | 40 | QAM 256 | 10 |
12 | 218000000 | 7.9 | 40 | QAM 256 | 11 |
13 | 226000000 | 7.8 | 40 | QAM 256 | 12 |
14 | 234000000 | 7.6 | 40 | QAM 256 | 13 |
15 | 242000000 | 7.4 | 40 | QAM 256 | 14 |
16 | 250000000 | 7.4 | 40 | QAM 256 | 15 |
17 | 258000000 | 7.5 | 40 | QAM 256 | 16 |
18 | 266000000 | 7.7 | 40 | QAM 256 | 17 |
19 | 274000000 | 7.8 | 40 | QAM 256 | 18 |
20 | 282000000 | 7.7 | 40 | QAM 256 | 19 |
21 | 298000000 | 7.3 | 40 | QAM 256 | 21 |
22 | 306000000 | 7.3 | 40 | QAM 256 | 22 |
23 | 314000000 | 7.6 | 40 | QAM 256 | 23 |
24 | 322000000 | 7.9 | 40 | QAM 256 | 24 |
25 | 330000000 | 7.9 | 40 | QAM 256 | 25 |
26 | 338000000 | 7.9 | 40 | QAM 256 | 26 |
27 | 346000000 | 7.8 | 41 | QAM 256 | 27 |
28 | 354000000 | 7.7 | 41 | QAM 256 | 28 |
29 | 362000000 | 7.9 | 41 | QAM 256 | 29 |
30 | 370000000 | 8 | 41 | QAM 256 | 30 |
31 | 378000000 | 8 | 41 | QAM 256 | 31 |
32 | 386000000 | 7.8 | 41 | QAM 256 | 32 |
1 | Locked | 40 | 0 | 0 |
2 | Locked | 40 | 1 | 0 |
3 | Locked | 40 | 1 | 0 |
4 | Locked | 40 | 4 | 0 |
5 | Locked | 40 | 1 | 0 |
6 | Locked | 40 | 2 | 0 |
7 | Locked | 40 | 2 | 0 |
8 | Locked | 40 | 2 | 0 |
9 | Locked | 40 | 1 | 0 |
10 | Locked | 40 | 0 | 0 |
11 | Locked | 40 | 2 | 0 |
12 | Locked | 40 | 3 | 0 |
13 | Locked | 40 | 1 | 0 |
14 | Locked | 40 | 5 | 0 |
15 | Locked | 40 | 5 | 0 |
16 | Locked | 40 | 3 | 0 |
17 | Locked | 40 | 0 | 0 |
18 | Locked | 40 | 3 | 0 |
19 | Locked | 40 | 1 | 0 |
20 | Locked | 40 | 1 | 0 |
21 | Locked | 40 | 1 | 0 |
22 | Locked | 40 | 2 | 0 |
23 | Locked | 40 | 0 | 0 |
24 | Locked | 40 | 3 | 0 |
25 | Locked | 40 | 1 | 0 |
26 | Locked | 40 | 0 | 0 |
27 | Locked | 41 | 2 | 0 |
28 | Locked | 41 | 2 | 0 |
29 | Locked | 41 | 1 | 0 |
30 | Locked | 41 | 4 | 0 |
31 | Locked | 41 | 1 | 0 |
32 | Locked | 41 | 0 | 0 |
3.1 Downstream channels
159 | 92 | 4K | 1800 | QAM 4096 | 1128 |
159 | Locked | 42 | 8.1 | 1608316297 | 0 |
3.0 Upstream channels
0 | 49600000 | 40.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 40.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 40.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 40.5 | 5120 | QAM 64 | 4 |
4 | 23600000 | 40 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
6 | 10 | 34.5 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 16 | 1 |
23-02-2024 21:46:22 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 21:46:22 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 17:02:23 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 17:02:23 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 16:31:54 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 16:31:54 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 15:40:37 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
23-02-2024 15:40:37 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-02-2024 18:34:12 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
22-02-2024 18:30:56 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:33 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:33 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:30 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
21-02-2024 22:57:24 | warning | Dynamic Range Window violation |
21-02-2024 22:57:24 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:24 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:24 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:19 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:11 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:57:09 | notice | Honoring MDD; IP provisioning mode = IPv4 |
21-02-2024 22:56:39 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
21-02-2024 22:56:38 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
24-02-2024 16:06 - edited 24-02-2024 16:10
Hub stats all look good to me - logs are odd and BQM is poor though ...
A VM person should take a look and comment here soon
on 27-02-2024 08:02
Hey @h6LuUsx8 Thanks for reaching out to us and a big warm welcome to the Virgin Media Community forums. 👋🏼
I'm sorry to hear about the latency spikes and packet loss you are experiencing.
I will assist you on the matter and look in to this for you.
I will send a private message to further assist.
Kind regards,
Ilyas.
