StokieAndy's avatar
StokieAndy
Is it actually possible to order a wi-fi pod before I die of old age?
I have a wi-fi black spot, so wanted to order a wi-fi pod, but it's proving very tricky. I looked at how to order a wi-fi pod and it directs me to the VM connect app. Apparently if the app detects a speed lower than your contract it directs you to ordering a pod. However, I use the app in most of the house and the speed is fine. If I use the app in the black spot it just says 'Oops, something went wrong' and directs me to My Virgin Media. If I login to My Virgin Media there's nowhere to order a pod. If I try to chat I get a useless bot that tells me to use the VM connect app. If i try to phone I get a similar runaround.  And so on and so on ad nauseam.
What really galls is that I didn't even know about the wi-fi pods until Virgin emailed me and said why don't you get a pod ðŸ˜¡
  • Hi StokieAndy, thank you for your post.
    We're sorry to hear about the problems you've been having when trying to order a WiFi Pod 😔
    In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Regards,
    Daniel
  • Daniel_Et's avatar
    Daniel_Et
    Regards,
    Daniel
    • StokieAndy's avatar
      StokieAndy
      Pod arrived and black spot is solved. Thanks Daniel. ðŸ˜€
