on 22-01-2024 12:50
Late in 2023 I was upgraded to the Hub5 with 1GB speed. Ever since then I am having regular internet disconnects, sometimes 3-4 times per hour. These usually last for around 15 seconds but are really annoying. The hub error message is below, is anyone else getting this after upgrading.
DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value
US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13
on 22-01-2024 15:35
Can we check… are your drop outs only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one - to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
on 22-01-2024 16:02
Its on both, my virgin tv box and xbox are connected by ethernet and I get these annoying drops there too. I have made a habit of checking the logs for the time of the error messages and they match up Some days seem worse than others but every time there is a drop I get the error message.
on 22-01-2024 16:08
Lets see the data, can you do this...
______________________________
Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 22-01-2024 16:15
Downstream
1 | 331000000 | 3 | 42 | QAM 256 | 25 |
2 | 187000000 | 3.6 | 43 | QAM 256 | 7 |
3 | 195000000 | 3.8 | 42 | QAM 256 | 8 |
4 | 203000000 | 3.8 | 42 | QAM 256 | 9 |
5 | 211000000 | 4 | 42 | QAM 256 | 10 |
6 | 219000000 | 4.1 | 42 | QAM 256 | 11 |
7 | 227000000 | 4.1 | 42 | QAM 256 | 12 |
8 | 235000000 | 4.1 | 42 | QAM 256 | 13 |
9 | 243000000 | 3.8 | 42 | QAM 256 | 14 |
10 | 251000000 | 3.7 | 42 | QAM 256 | 15 |
11 | 259000000 | 3.9 | 42 | QAM 256 | 16 |
12 | 267000000 | 3.9 | 43 | QAM 256 | 17 |
13 | 275000000 | 3.9 | 43 | QAM 256 | 18 |
14 | 283000000 | 3.9 | 43 | QAM 256 | 19 |
15 | 291000000 | 4 | 43 | QAM 256 | 20 |
16 | 299000000 | 4 | 43 | QAM 256 | 21 |
17 | 307000000 | 3.8 | 42 | QAM 256 | 22 |
18 | 315000000 | 3.7 | 43 | QAM 256 | 23 |
19 | 323000000 | 3.3 | 42 | QAM 256 | 24 |
20 | 339000000 | 2.9 | 42 | QAM 256 | 26 |
21 | 347000000 | 2.9 | 42 | QAM 256 | 27 |
22 | 355000000 | 2.8 | 42 | QAM 256 | 28 |
23 | 363000000 | 2.8 | 42 | QAM 256 | 29 |
24 | 371000000 | 2.9 | 42 | QAM 256 | 30 |
25 | 379000000 | 3 | 42 | QAM 256 | 31 |
26 | 387000000 | 3 | 42 | QAM 256 | 32 |
27 | 491000000 | 2.3 | 42 | QAM 256 | 33 |
28 | 499000000 | 2.1 | 42 | QAM 256 | 34 |
29 | 507000000 | 1.9 | 42 | QAM 256 | 35 |
30 | 515000000 | 1.4 | 42 | QAM 256 | 36 |
31 | 523000000 | 1.1 | 41 | QAM 256 | 37 |
32 | 531000000 | 1 | 42 | QAM 256 | 38 |
1 | Locked | 42 | 0 | 0 |
2 | Locked | 43 | 16 | 0 |
3 | Locked | 42 | 23 | 0 |
4 | Locked | 42 | 12 | 0 |
5 | Locked | 42 | 14 | 0 |
6 | Locked | 42 | 57 | 0 |
7 | Locked | 42 | 7 | 0 |
8 | Locked | 42 | 17 | 0 |
9 | Locked | 42 | 8 | 0 |
10 | Locked | 42 | 0 | 0 |
11 | Locked | 42 | 0 | 0 |
12 | Locked | 43 | 0 | 0 |
13 | Locked | 43 | 0 | 0 |
14 | Locked | 43 | 0 | 0 |
15 | Locked | 43 | 0 | 0 |
16 | Locked | 43 | 0 | 0 |
17 | Locked | 42 | 0 | 0 |
18 | Locked | 43 | 0 | 0 |
19 | Locked | 42 | 0 | 0 |
20 | Locked | 42 | 0 | 0 |
21 | Locked | 42 | 2 | 0 |
22 | Locked | 42 | 1 | 0 |
23 | Locked | 42 | 1 | 0 |
24 | Locked | 42 | 0 | 0 |
25 | Locked | 42 | 1 | 0 |
26 | Locked | 42 | 13 | 0 |
27 | Locked | 42 | 27 | 0 |
28 | Locked | 42 | 22 | 0 |
29 | Locked | 42 | 30 | 0 |
30 | Locked | 42 | 18 | 0 |
31 | Locked | 41 | 98 | 0 |
32 | Locked | 42 | 119 | 0 |
3.1 Downstream channels
159 | 94 | 4K | 1840 | QAM 4096 | 1108 |
159 | Locked | 44 | 3.6 | 1273221669 | 4572 |
Upstream
3.0 Upstream channels
0 | 49600000 | 47.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 47.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 47.8 | 5120 | QAM 64 | 3 |
3 | 30100000 | 47.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 46.8 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 3 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
3.1 Upstream channels
6 | 10 | 41.5 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 0 | 0 |
on 22-01-2024 16:23
22-01-2024 16:09:38 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 16:09:38 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 16:09:13 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 16:09:13 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:38:43 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:38:43 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:38:19 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:38:19 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:07:49 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:07:49 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:07:25 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 15:07:25 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:36:55 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:36:55 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:36:20 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:36:20 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:05:50 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:05:50 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:05:06 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 14:05:06 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:34:36 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:34:36 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:34:12 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:34:12 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:03:42 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:03:42 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:03:18 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 13:03:18 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 12:32:48 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 12:32:48 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 12:32:14 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 12 13.;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
22-01-2024 12:32:14 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=-;CMTS-MAC=-;CM-QOS=1.1;CM-VER=3.1; |
on 24-01-2024 17:30
Hi Markw13 👋
Thanks for posting, and welcome back to the Forums.
I'm sorry to hear you're having problems with your service. I'm going to send you a private message, to assist further with this, please look out for it in the top-right, white envelope or by tapping your profile picture and then "Messages".
