Mike2608's avatar
Mike2608
9 months ago
Hub issues red light
My router has had a solid red light hub 3 for over a year now! I’ve also been having issues with my WiFi dropping on a regular basis. I spoke numerously to virgin media a few times and every time the advice is different by the technical people mainly to reset the hub which is done on a regular basis and then they say they are doing technical work in the area… Sorry buy for a whole year!!
  • Hi Mike2608 👋 Welcome to the community forum! Thanks for posting.
    Sorry to hear these concerns about your Hub 3 - this sounds less than ideal!
    I'd like to take a closer look and arrange a replacement being sent to you if needed. We will just need to send you a PM to confirm a few account details so we can arrange this for you.
    I will do this for you now - you can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
    Wishing you all the best. 🌞
    • Mike2608's avatar
      Mike2608
      Thank you Molly, I have responded as per your mail.
