wright_here22's avatar
wright_here22
4 years ago
Hub 5 - Is it true you cant use 2.5gb WAN port in Modem mode?
Hi Everyone,
So, I have 1Gb connection which is working and with that I got a new Hub 5. The WIFI was hopeless and kept dropping out.
So, i will be (as many of you have/do) go over to a 3rd party wifi router, however i have now read that you can only connect via network port 1 which is 1gb only. Can this be right?
Some wireless routers have a 2.5gb WAN so thought that would be great to maximise my speed.
Why on earth does Virgin not allow the use of a 2.5gb port?
Thanks in advance
  • They do. I have my SH5 in modem connected to my Unifi Dream Machine Pro router using the 2.5Gb ports
    • wright_here22's avatar
      wright_here22
      So...
      This is where I got the information from....
      Re: hub 5 modem mode
      on ‎16-05-2022 16:10
      Hi @kannanni - thanks for getting in touch. I hope you're enjoying the Hub 5 and all of the benefits and features it has to offer!
      When in Modem Mode, only one port on your Hub 5 will work - this will be Port 1. Once you have connected this up to your equipment, you'll just need to give your Hub 5 a quick reboot and it will then be configured on our end. You'll then need to configure your equipment as per the manufacturer's guide.
      @shecal to get your Hub 5 into Modem Mode, you can follow the guide here: https://www.virginmedia.com/help/broadband/reboot-or-reset-hub and then selecting the "Putting the Hub into modem/router mode".
      Cheers,
      Reece - Forum Team
      • bally12345's avatar
        bally12345
        Dialled in
        Iv not looked at the numbers but the 2.5gb port 100% works.
        They might have meant one port, rather than port 1?
        Or more likely they simply mistaken. As if that was the case there really would be zero advantage especially as 1gbps tops out around 930mbps on gigabit eth
  • Hi wright_here22 thanks for your post although I'm sorry to hear of your concerns raised here.
    I do apologise for the confusion here, hopefully thanks to Adduxi and Tudor and bally12345's help, you've been able to get this sorted!
    If you need any further help in the future please don't hesitate to let us know.
    Many thanks
  • martin9595's avatar
    martin9595
    I got my hub 5 today (was on 1gig with a hub4) and the 2.5gbps port works as expected in modem mode.  This is my connection in pfsense
    • Natalie_L's avatar
      Natalie_L
      Thank you for updating the thread martin9595.
      Please get in touch if we can assist in the future.
