Tonyf100's avatar
Tonyf100
Hub 5 Ethernet problem
Hi all, I’m having major problems with my hub 5 router, the wifi works ok…. Until I plug in an Ethernet cable, when I connect one the WiFi just drops. We had an engineer out a while back and all he said was to just use WiFi. My problem with that is I have a cctv system that needs an Ethernet connection.
any ideas on what the problem is and what the I can do to get it sorted
