Showing results forΒ
Search instead forΒ
Did you mean:Β
Hub 3 solid red light.
SweetFA
Hello Virgins. ✌🏼
As the title suggests! The light at the front has a solid red light instead of the solid white.
This hasn't changed after a reboot and a reset. πŸ€·πŸΌβ€β™‚οΈ
My understanding is that a new hub is needed πŸ™„
I look forward to hearing from VM.
Many thanks. πŸ‘πŸΌ
1 ACCEPTED SOLUTION
Accepted Solutions
Daniel_Et
Hi @SweetFA, thank you for your post.
We're sorry to hear about the problem you're having πŸ˜”
In order to discuss this with you, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
1 REPLY 1
Daniel_Et
Regards,
Daniel
