SweetFA's avatar
SweetFA
8 months ago
Hub 3 solid red light.
Hello Virgins. ✌🏼 As the title suggests! The light at the front has a solid red light instead of the solid white. This hasn't changed after a reboot and a reset. 🤷🏼‍♂️ My understanding is that ...
  • Daniel_Et's avatar
    8 months ago
    Hi SweetFA, thank you for your post.
    We're sorry to hear about the problem you're having 😔
    In order to discuss this with you, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Regards,
    Daniel
