on 07-08-2024 08:58
Hi Carley, I have the same problem. Hub 3, red light on but connecting all ok. I called in to report the fault and they said it was due to WiFi upgrades in my area and would go in a few days. That doesn't sound right to me. I am worried about potential overheating. Please advise on next steps asap, thanks
[MOD EDIT: Post split to create own thread]
on 09-08-2024 12:03
Hi there,
I'm sorry to hear about the red light on your hub.
If you've done the below, and the light remains, you'll need a replacement.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
I'll send you a private message now.
Please look out for the envelope in the top right of the page and pop back to me when you can.
Vikki - Forum Team
