on 16-02-2024 13:52
Hi, we reconnected our Hub yesterday after 2 months whilst we had building work carried out in the house. Our Hub 3 now has a permanent red light showing, never had issues before. We do appear to have internet though.
I have reset a few times including 30 sec press of reset button at back. Feels slightly warm to touch, should I be concerned about overheating?
Regards,
on 16-02-2024 14:35
Run the Network diagnostic tool ( from the Hub 3 menu )
Scroll down through the results and find the Temperature entry. Is it normal ?
on 29-02-2024 13:34
Thanks for your reply. Yes, temperature normal.
Possibly starting to have other issues as well as permanent red light. A few times hub has lost internet connection and when I 'check service status; and click 'Test your Hub' every time it says 'Looks like we nee to reset the Hub'.
on 29-02-2024 14:27
Hi terraloam72 👋
Thanks for posting, and a warm welcome to the Forums.
I'm very sorry to hear you're seeing a red light on your Hub. I'm going to send you a private message to assist further. Please look out for it in the top-right, white envelope or by tapping your profile picture and selecting "Messages".
on 05-03-2024 16:16
Issues resolve!! VM very quick in sending an engineer to replace hub and check connections etc. 🙂
