on 17-02-2024 23:05
I had posted in the gaming support, but felt that a more detailed post here is likely to get a better response.
For a considerable length of time - probably at least 9 months, if not more - I have been suffering from frequent but irregular packetloss on my VM Fibre connection.
It was first noticed as on Microsoft Teams/Zoom calls when working from home my colleagues would report that I would occassionally freeze up, even though I could still see and hear them. As this was the only symptom (that I had noticed) I chalked it up to a connection with Teams/Zoom rather than an ISP issue. However over the last few months I have noticed when using online applications (in particular games) which require a constant connection that I get a frequent but irregular dropout causing packetburst/packetloss and the associated impact on gameplay and service that you would expect.
At the end of January I set up a BQM to check, and the frequent spikes are clearly shown. I have done all the standard troubleshooting steps - rebooting the Hub, checking the cables, resetting and so on. However a quick comparison of my Network Log to some historic cases on the forum seem to indicate that this is an issue with VM itself.
1 | 387000000 | 1.5 | 40 | 256 qam | 32 |
2 | 139000000 | -2.2 | 38 | 256 qam | 1 |
3 | 147000000 | -2.4 | 38 | 256 qam | 2 |
4 | 155000000 | -2.4 | 38 | 256 qam | 3 |
5 | 163000000 | -2.5 | 38 | 256 qam | 4 |
6 | 171000000 | -2 | 38 | 256 qam | 5 |
7 | 179000000 | -1.7 | 38 | 256 qam | 6 |
8 | 187000000 | -1.2 | 38 | 256 qam | 7 |
9 | 195000000 | -1.4 | 40 | 256 qam | 8 |
10 | 203000000 | -1.5 | 40 | 256 qam | 9 |
11 | 211000000 | -1.4 | 40 | 256 qam | 10 |
12 | 219000000 | -1.4 | 38 | 256 qam | 11 |
13 | 227000000 | -1.5 | 38 | 256 qam | 12 |
14 | 235000000 | -1.4 | 40 | 256 qam | 13 |
15 | 291000000 | 0.5 | 40 | 256 qam | 20 |
16 | 299000000 | 1 | 40 | 256 qam | 21 |
17 | 307000000 | 1.4 | 40 | 256 qam | 22 |
18 | 315000000 | 1.5 | 40 | 256 qam | 23 |
19 | 323000000 | 1.7 | 40 | 256 qam | 24 |
20 | 347000000 | 1.9 | 40 | 256 qam | 27 |
21 | 355000000 | 1.7 | 40 | 256 qam | 28 |
22 | 363000000 | 1.4 | 40 | 256 qam | 29 |
23 | 371000000 | 1.2 | 40 | 256 qam | 30 |
24 | 379000000 | 1.5 | 40 | 256 qam | 31 |
1 | Locked | 40.3 | 19805 | 195715 |
2 | Locked | 38.6 | 108947 | 8023 |
3 | Locked | 38.6 | 52769 | 822193 |
4 | Locked | 38.6 | 49273 | 8436 |
5 | Locked | 38.9 | 44176 | 13074 |
6 | Locked | 38.9 | 70334 | 16532 |
7 | Locked | 38.6 | 24687 | 14993 |
8 | Locked | 38.6 | 15787 | 15846 |
9 | Locked | 40.3 | 10755 | 18079 |
10 | Locked | 40.3 | 18843 | 15205 |
11 | Locked | 40.3 | 6822 | 16780 |
12 | Locked | 38.9 | 7184 | 14446 |
13 | Locked | 38.6 | 10854 | 14582 |
14 | Locked | 40.3 | 12308 | 15733 |
15 | Locked | 40.9 | 19231 | 15266 |
16 | Locked | 40.3 | 5665 | 16485 |
17 | Locked | 40.3 | 4833 | 17544 |
18 | Locked | 40.3 | 5159 | 19561 |
19 | Locked | 40.9 | 6166 | 20477 |
20 | Locked | 40.3 | 4690 | 16440 |
21 | Locked | 40.9 | 4065 | 17475 |
22 | Locked | 40.9 | 4659 | 16458 |
23 | Locked | 40.3 | 4634 | 18992 |
24 | Locked | 40.3 | 2663 | 63053 |
1 | 30100000 | 40.3 | 5120 | 64 qam | 4 |
2 | 23600000 | 40.3 | 5120 | 64 qam | 5 |
3 | 36600000 | 40.8 | 5120 | 64 qam | 3 |
4 | 43100000 | 40.3 | 5120 | 64 qam | 2 |
5 | 49600000 | 40.8 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 6 | 0 |
4 | ATDMA | 0 | 0 | 4 | 0 |
5 | ATDMA | 0 | 0 | 4 | 0 |
on 17-02-2024 21:24
I've been having issues with my Virgin Media fibre connection. At first, all I noticed was that occasionally during Microsoft Teams/Zoom calls whilst working from home, I would occasionally "drop" connection - though I could still see and hear other participants, my feed would freeze for them.
Initially I shrugged this off as a quirk of those programs, as I was still receiving video streams. However, when gaming I noticed that I would get frequent (but irregular) packetburst and packetloss. This was intrusive, but also in some games causes autodisconnects even though the packetburst lasts for only a brief moment. As such this has made any sort of online gaming practically impossible. At the end of January I set up a Broadband Quality Monitor, and it shows these packetbursts very clearly.
The fact that they also happen in the small hours of the morning, although less frequently, indicates that this is likely an issue with the ISP rather than due to anything on my end as there is no usage during those times.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f6e7219aa16706904a3e11d10b23dcc1d2a35e2b
I've checked through all the standard checklists, checked physical cable connections, rebooted the router etc. but to no avail. Virgin seems to have a brick wall when trying to contact them to address this however.
on 17-02-2024 23:05
17/02/2024 23:02:28 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 22:52:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 22:43:11 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 20:05:52 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 19:26:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 18:46:19 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 16:42:17 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 10:00:24 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/02/2024 08:21:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 17:09:32 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 15:57:18 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 13:46:37 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 12:53:21 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 10:36:46 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 09:53:7 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 01:09:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/02/2024 01:08:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2024 16:24:5 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2024 15:12:4 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/02/2024 15:12:4 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17-02-2024 23:06 - edited 17-02-2024 23:08
BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0915288b112434c06630f6524a48049087b3d716-17-02-2024
on 20-02-2024 11:18
Hi @Milney 👋.
Thanks for reaching out to us and welcome to the Community Forums. Apologies for the issues that you have been having with your internet. We can certainly assist you, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
