andy1027's avatar
andy1027
Up to speed
Flaky connection - Belfast - Intermittent
Moved home recently this year and took our VM kit with us as per the moving home process. We've had a good connection using the Super Hub 3 (in Modem mode). In the last two weeks we have noticed the connection to be flaky and has dropped out completely at times. We have rebooted our kit several times and checked the connections on all the cabling.
I took a look at the power levels on the super hub and have had a BB monitor running for the last few days to try and get a look on this.
Would be grateful for a forum moderator to run some tests on our line to ascertain if we need a technician to visit. Thank you
See below BB snapshot graph and stats from the modem.
SUPER HUB 3.0 (Modem Mode)
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
9.1
40
256 qam
9
2
139000000
8.8
37
256 qam
1
3
163000000
10.4
40
256 qam
4
4
171000000
10.5
40
256 qam
5
5
195000000
9.5
40
256 qam
8
6
227000000
9.1
40
256 qam
12
7
235000000
9.5
40
256 qam
13
8
243000000
9.5
40
256 qam
14
9
251000000
10
40
256 qam
15
10
275000000
10.8
40
256 qam
18
11
283000000
11.5
40
256 qam
19
12
307000000
12.1
38
256 qam
22
13
315000000
11.9
40
256 qam
23
14
331000000
11.9
40
256 qam
25
15
339000000
11.5
40
256 qam
26
16
347000000
11.5
40
256 qam
27
17
355000000
11.4
40
256 qam
28
18
363000000
11.4
40
256 qam
29
19
371000000
11.3
40
256 qam
30
20
379000000
10.9
38
256 qam
31
21
387000000
11.6
40
256 qam
32
22
395000000
12
40
256 qam
33
23
403000000
12.3
40
256 qam
34
24
419000000
12.4
40
256 qam
36
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
4376587
979414
2
Locked
37.6
5606647
2738070
3
Locked
40.3
3649776
1663622
4
Locked
40.3
3666532
1477538
5
Locked
40.3
3604484
1045672
6
Locked
40.3
3349111
627535
7
Locked
40.3
3272514
547070
8
Locked
40.3
3186905
473055
9
Locked
40.3
3097264
413716
10
Locked
40.3
2783774
256886
11
Locked
40.3
2679305
220738
12
Locked
38.9
2361308
132667
13
Locked
40.3
2245594
111520
14
Locked
40.9
2044959
82102
15
Locked
40.3
1961773
71707
16
Locked
40.9
1834799
58936
17
Locked
40.3
1746267
51260
18
Locked
40.3
1712543
47918
19
Locked
40.3
1553984
37356
20
Locked
38.9
1494439
33636
21
Locked
40.3
1431158
30873
22
Locked
40.3
1328795
26236
23
Locked
40.3
1201483
19707
24
Locked
40.3
1117144
18647
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
49600000
45.3
5120
64 qam
1
2
23600000
46
5120
64 qam
5
3
30100000
46
5120
64 qam
4
4
36600000
45
5120
64 qam
3
5
43100000
46.5
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
4
0
2
ATDMA
0
0
14
0
3
ATDMA
0
0
2
0
4
ATDMA
0
0
7
0
5
ATDMA
0
0
3
0
  • Network Log
    Time
    Priority
    Description
    02/10/2024 21:07:29
    Warning!
    RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/10/2024 20:18:12
    critical
    SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/10/2024 18:54:6
    Warning!
    02/10/2024 18:38:50
    critical
    02/10/2024 13:47:30
    Warning!
    02/10/2024 13:46:56
    Warning!
    Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    02/10/2024 13:45:52
    Warning!
    02/10/2024 13:45:48
    critical
    02/10/2024 13:45:42
    Warning!
    02/10/2024 13:45:16
    Warning!
    02/10/2024 13:44:49
    critical
    02/10/2024 13:44:40
    critical
    02/10/2024 13:44:28
    Warning!
    02/10/2024 13:44:23
    Warning!
    02/10/2024 13:43:56
    Warning!
    02/10/2024 13:43:47
    critical
    02/10/2024 13:43:11
    critical
    02/10/2024 13:42:51
    Warning!
    02/10/2024 13:42:27
    critical
    02/10/2024 13:42:7
    critical
    General Configuration
    Network access
    Allowed
    Maximum Number of CPEs
    1
    Baseline Privacy
    Enabled
    DOCSIS Mode
    Docsis30
    Config file
    rkldJKDHSUBsgvca69834ncxv
    SFID
    31122
    Max Traffic Rate
    143750047
    Max Traffic Burst
    42600
    Min Traffic Rate
    0
    Primary Upstream Service Flow
    SFID
    31119
    Max Traffic Rate
    22000047
    Max Traffic Burst
    42600
    Min Traffic Rate
    0
    Max Concatenated Burst
    42600
    Scheduling Type
    BestEffort
  • legacy1's avatar
    Looks like upstream noise they will likely say its downstream power and fix that and you still have problems
  • It can take several hours to a week for a reply from VM, however, they may not have access to your account and HUB to troubleshoot since you are based in Belfast.
