on 01-09-2024 17:02
Hello.
Since the start of August we've been seeing a drop in upload speed from ~100MBps to 0.0, sometimes maybe 1. VM sent out an engineer, re-pulled our cable and yet the issue persists. A family member in the area said they experience the same thing and then finally VM said it was an area SNR issue and they would fix it.
When the 2 week fix date came it did get sorted, but within a week it was back. Then a fix for 2-3 days and then it was back. I've called them every time and had responses from 'we will log the call' to sending me unwanted and unneeded equipment. I've said many times that it is the same issue as before and there are other people in the area getting the same problem, but the customer 'service' don't seem to be able to think beyond the script.
I'm getting a little tired of having to start the same conversation over and over with the call centre as I just want to continue with the original fault that obviously hasn't been fixed. It's super frustrating.
you can see from the BQM (they are all like this) that it starts regular between 4 and 6pm and lasts into the night.
Is anyone able to advise or someone from VM able to contact me about this particular issue so I don't have to log this as if it's not been going on for a month?
cheers
this is a link to the BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/de86296c988c85da62864f7379703f267a...
3.0 Upstream channels
0 | 49600000 | 48 | 5120 | QAM 16 | 1 |
1 | 43100000 | 47 | 5120 | QAM 16 | 2 |
2 | 36600000 | 46 | 5120 | QAM 16 | 3 |
3 | 30100000 | 45.5 | 5120 | QAM 16 | 4 |
4 | 23600000 | 44.3 | 5120 | QAM 16 | 9 |
0 | ATDMA | 0 | 6074 | 87 | 0 |
1 | ATDMA | 0 | 6074 | 83 | 0 |
2 | ATDMA | 0 | 6074 | 84 | 0 |
3 | ATDMA | 0 | 6074 | 128 | 0 |
4 | ATDMA | 0 | 6074 | 87 | 0 |
3.1 Upstream channels
10 | 10.4 | 43.5 | 2K | QAM 256 |
10 | OFDMA | 208 | 74000000 | 17908 | 0 |
3.0 Downstream channels
1 | 499000000 | 2.9 | 39 | QAM 256 | 12 |
2 | 411000000 | 3.5 | 39 | QAM 256 | 1 |
3 | 419000000 | 2.9 | 39 | QAM 256 | 2 |
4 | 427000000 | 2.7 | 39 | QAM 256 | 3 |
5 | 435000000 | 2.8 | 39 | QAM 256 | 4 |
6 | 443000000 | 2.6 | 39 | QAM 256 | 5 |
7 | 451000000 | 2.9 | 39 | QAM 256 | 6 |
8 | 459000000 | 2.5 | 39 | QAM 256 | 7 |
9 | 467000000 | 2.7 | 39 | QAM 256 | 8 |
10 | 475000000 | 2.4 | 39 | QAM 256 | 9 |
11 | 483000000 | 2.7 | 39 | QAM 256 | 10 |
12 | 491000000 | 2.6 | 39 | QAM 256 | 11 |
13 | 507000000 | 3.1 | 39 | QAM 256 | 13 |
14 | 515000000 | 3.3 | 39 | QAM 256 | 14 |
15 | 523000000 | 3.6 | 39 | QAM 256 | 15 |
16 | 531000000 | 4 | 39 | QAM 256 | 16 |
17 | 539000000 | 4.3 | 40 | QAM 256 | 17 |
18 | 547000000 | 4.7 | 40 | QAM 256 | 18 |
19 | 555000000 | 4.7 | 40 | QAM 256 | 19 |
20 | 563000000 | 4.7 | 40 | QAM 256 | 20 |
21 | 571000000 | 4.4 | 40 | QAM 256 | 21 |
22 | 579000000 | 4.3 | 40 | QAM 256 | 22 |
23 | 587000000 | 3.9 | 40 | QAM 256 | 23 |
24 | 595000000 | 3.8 | 40 | QAM 256 | 24 |
25 | 603000000 | 3.3 | 40 | QAM 256 | 25 |
26 | 611000000 | 3.2 | 40 | QAM 256 | 26 |
27 | 619000000 | 2.5 | 39 | QAM 256 | 27 |
28 | 627000000 | 2.6 | 39 | QAM 256 | 28 |
29 | 635000000 | 2.4 | 39 | QAM 256 | 29 |
30 | 643000000 | 2.5 | 39 | QAM 256 | 30 |
31 | 651000000 | 2.4 | 39 | QAM 256 | 31 |
1 | Locked | 39 | 154 | 0 |
2 | Locked | 39 | 200 | 0 |
3 | Locked | 39 | 195 | 0 |
4 | Locked | 39 | 186 | 0 |
5 | Locked | 39 | 166 | 0 |
6 | Locked | 39 | 180 | 0 |
7 | Locked | 39 | 172 | 0 |
8 | Locked | 39 | 218 | 0 |
9 | Locked | 39 | 188 | 0 |
10 | Locked | 39 | 227 | 0 |
11 | Locked | 39 | 189 | 0 |
12 | Locked | 39 | 181 | 0 |
13 | Locked | 39 | 140 | 0 |
14 | Locked | 39 | 136 | 0 |
15 | Locked | 39 | 113 | 0 |
16 | Locked | 39 | 114 | 0 |
17 | Locked | 40 | 55 | 0 |
18 | Locked | 40 | 46 | 0 |
19 | Locked | 40 | 64 | 0 |
20 | Locked | 40 | 62 | 0 |
21 | Locked | 40 | 55 | 0 |
22 | Locked | 40 | 101 | 0 |
23 | Locked | 40 | 102 | 0 |
24 | Locked | 40 | 103 | 0 |
25 | Locked | 40 | 164 | 0 |
26 | Locked | 40 | 174 | 0 |
27 | Locked | 39 | 243 | 0 |
28 | Locked | 39 | 228 | 0 |
29 | Locked | 39 | 257 | 0 |
30 | Locked | 39 | 259 | 0 |
31 | Locked | 39 | 244 | 0 |
3.1 Downstream channels
37 | 94 | 4K | 1840 | QAM 4096 | 1108 |
37 | Locked | 39 | 0.4 | 2943049382 | 1543198 |
on 02-09-2024 10:03
The ticket number for this outage is F011468264 😊
on 02-09-2024 10:17
Thanks, Beth. For the benefit of the user, obviously P1 is highest priority and gains management attention. This priority is typically assigned to large scale outages. P1s also arise when P2s have passed their resolution target time - or so it should be in any good service organisation. P1s should be resolved within a certain number of hours, in my experience less than 4 - but I don't know VM's policy on this.
P2 sits behind P1 and gains top attention when there are no P1s outstanding. But they are also worked on if the resources used by P1s don't affect P2s. In my experience, P2s need resolution within 8 hours and should be worked on within 2 hours of ticket issue.
P3 tickets are supposed to be of a more 'routine' nature, requiring a response within same day or next morning and resolution within 24 hours depending on policy.
SNR issues, as I've stated, are notoriously difficult to pinpoint, requiring special tools and methods for tracking the source down over a potentially wide area and often out of office hours. In other words, resolution time is indeterminate - yet a priority must be assigned. It can't be P1/P2 because of the strict resolution targets; it can't be P4 which is the bottom of the pile because it is an area fault.
What I've said won't get it resolved any faster, but it might help knowing how the problem system is supposed to work.
