manytentacles's avatar
manytentacles
Drop to 0.0 upload speed for the past month
Hello.
Since the start of August we've been seeing a drop in upload speed from ~100MBps to 0.0, sometimes maybe 1. VM sent out an engineer, re-pulled our cable and yet the issue persists. A family member in the area said they experience the same thing and then finally VM said it was an area SNR issue and they would fix it.
When the 2 week fix date came it did get sorted, but within a week it was back. Then a fix for 2-3 days and then it was back. I've called them every time and had responses from 'we will log the call' to sending me unwanted and unneeded equipment. I've said many times that it is the same issue as before and there are other people in the area getting the same problem, but the customer 'service' don't seem to be able to think beyond the script.
I'm getting a little tired of having to start the same conversation over and over with the call centre as I just want to continue with the original fault that obviously hasn't been fixed. It's super frustrating.
you can see from the BQM (they are all like this) that it starts regular between 4 and 6pm and lasts into the night.
Is anyone able to advise or someone from VM able to contact me about this particular issue so I don't have to log this as if it's not been going on for a month?
cheers
this is a link to the BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/de86296c988c85da62864f7379703f267ad45767-01-09-2024
 https://www.thinkbroadband.com/broadband/monitoring/quality/share/8c494d8da954c626bd8d7a836dbead11b4f6675f
3.0 Upstream channels
049600000485120QAM 161
143100000475120QAM 162
236600000465120QAM 163
33010000045.55120QAM 164
42360000044.35120QAM 169
0ATDMA06074870
1ATDMA06074830
2ATDMA06074840
3ATDMA060741280
4ATDMA06074870
3.1 Upstream channels
1010.443.52KQAM 256
10OFDMA20874000000179080
3.0 Downstream channels
14990000002.939QAM 25612
24110000003.539QAM 2561
34190000002.939QAM 2562
44270000002.739QAM 2563
54350000002.839QAM 2564
64430000002.639QAM 2565
74510000002.939QAM 2566
84590000002.539QAM 2567
94670000002.739QAM 2568
104750000002.439QAM 2569
114830000002.739QAM 25610
124910000002.639QAM 25611
135070000003.139QAM 25613
145150000003.339QAM 25614
155230000003.639QAM 25615
16531000000439QAM 25616
175390000004.340QAM 25617
185470000004.740QAM 25618
195550000004.740QAM 25619
205630000004.740QAM 25620
215710000004.440QAM 25621
225790000004.340QAM 25622
235870000003.940QAM 25623
245950000003.840QAM 25624
256030000003.340QAM 25625
266110000003.240QAM 25626
276190000002.539QAM 25627
286270000002.639QAM 25628
296350000002.439QAM 25629
306430000002.539QAM 25630
316510000002.439QAM 25631
1Locked391540
2Locked392000
3Locked391950
4Locked391860
5Locked391660
6Locked391800
7Locked391720
8Locked392180
9Locked391880
10Locked392270
11Locked391890
12Locked391810
13Locked391400
14Locked391360
15Locked391130
16Locked391140
17Locked40550
18Locked40460
19Locked40640
20Locked40620
21Locked40550
22Locked401010
23Locked401020
24Locked401030
25Locked401640
26Locked401740
27Locked392430
28Locked392280
29Locked392570
30Locked392590
31Locked392440
3.1 Downstream channels
37944K1840QAM 40961108
37Locked390.429430493821543198
  • jbrennand's avatar
    Upstream connection looks dreadful - can you do this first.
    ______________________________________________
    Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
    Also check the Upstream QAM’s are all at 64 - if they are still dropping (to 32/16) then see message 3 here…
    https://community.virginmedia.com/t5/Networking-and-WiFi/Regular-Intermittent-Upstream-dropouts/td-p/5202486
  • Sephiroth's avatar
    Sephiroth
    Please have a look at this thread and then possibly hook up with the poster.
    https://community.virginmedia.com/t5/Networking-and-WiFi/Packet-loss-every-day-between-4pm-and-12am-exactly/td-p/5552657
    If you are in the same locality as the other person, there is an area issue (the other OP has checked with neighbours and they have the problem too).  If you are in a different locality - as in nowhere near - it gets even more interesting as there is a common mode somewhere.
    • manytentacles's avatar
      manytentacles
      Looks like we're in the same area. Well a couple of us are. thanks for the heads-up.
      • Beth_G's avatar
        Beth_G
        Hi manytentacles
        Thank you for your first post, welcome to the Community Forums.
        I'm sorry to hear you've been struggling with your connection since the start of August, I appreciate this must be getting quite frustrating now.
        I appreciate you've been advised this before, however there is still an ongoing SNR outage in your area which will be affecting your speeds and connection stability. This is likely why your repull didn't seem to improve things.
        The estimated fix date is showing for tomorrow at 9am. Please let us know how things are tomorrow and if you are still having issues, we can check this again for you.
        Kind regards
    Focus first on these VM connection items ...
    3.0 Upstream channels (QAM 64 is the expected mode, QAM 32 or 16 reflect line noise degradation)
    0ATDMA06074870
    1ATDMA06074830
    2ATDMA06074840
    3ATDMA060741280
    4ATDMA06074870
    Sephiroth
    These ones are difficult to fix because difficult to pinpoint the noise or whatever is affecting your upstream.  For example, a VM business user on an industrial estate nearby with electrically noisy equipment.  Takes some pinning down.
    Sephiroth
    Just to say, that the 'estimated fix date' is artificial.  I advise you to request the ticket number and priority from the Forum Team.  If it's a 'P4' then the estimate is worthless.  Area noise should be a P1 and there is no estimable fix date until the source of noise has been determined.
    Sephiroth
    Thanks, Beth.   For the benefit of the user, obviously P1 is highest priority and gains management attention. This priority is typically assigned to large scale outages.  P1s also arise when P2s have passed their resolution target time - or so it should be in any good service organisation.  P1s should be resolved within a certain number of hours, in my experience less than 4 - but I don't know VM's policy on this.
    P2 sits behind P1 and gains top attention when there are no P1s outstanding.  But they are also worked on if the resources used by P1s don't affect P2s.  In my experience, P2s need resolution within 8 hours and should be worked on within 2 hours of ticket issue.
    P3 tickets are supposed to be of a more 'routine' nature, requiring a response within same day or next morning and resolution within 24 hours depending on policy.
    SNR issues, as I've stated, are notoriously difficult to pinpoint, requiring special tools and methods for tracking the source down over a potentially wide area and often out of office hours.  In other words, resolution time is indeterminate - yet a priority must be assigned.  It can't be P1/P2 because of the strict resolution targets; it can't be P4 which is the bottom of the pile because it is an area fault.
    What I've said won't get it resolved any faster, but it might help knowing how the problem system is supposed to work.
