on 02-06-2023 20:29
Hi there. Am really hoping someone can help me!!!
We have recently moved home and had Virgin Media broadband installed with the “Hub 3”.
However my Sonos is not connecting to it.
The Sonos app is saying that if a router supports both 2.5Ghz and 5Ghz then they need to be split and renamed. I've tried this - I think - by going into the router settings then into Wireless then security and giving both different names. No joy.
One at a time I have also disabled each and tried, but again no joy.
Can anyone help at all please?
Thanks a million.
on 02-06-2023 20:54
Have you followed this Sonos guide?
https://support.sonos.com/en-gb/article/connect-sonos-to-a-new-router-or-wi-fi-network
on 03-06-2023 06:56
I have yes but it won't connect. The troubleshooting messages that caused me to take the steps detailed above are ...
on 03-06-2023 10:09
Are the renamed SSIDs (network names) showing correctly (shining okay)?
on 04-06-2023 20:43
Hi there. It's definitely retaining the settings and "shining". Still no joy though 😞
on 05-06-2023 07:59
Make sure the 2.4Ghz WiFi of the Hub is set to B/G/N mixed mode as per the Sonos instructions.
on 05-06-2023 21:17
I've followed the Sonos instructions and it's still not connecting.
Here's a screenshot of the Wireless signal settings:
on 08-06-2023 08:58
Hi urban_spaceman, thanks for reaching out on our help forums and welcome to the VM community. 🙂
We're sorry to see you've been struggling with connecting your Sonos speaker to the new hub 3 and VM network.
We'd love to best help with this, from what we can read above you've tried to split the frequencies and follow the advice from the Sonos App without luck so far.
Have you switched the smart Wi Fi feature off (channel optimisation off) on the hub settings when amending these to ensure the changes will stay on?
(Channel optimisation is set to switch back to the smart wireless default settings if on).
Have you by any chance tried to switch to WPA instead of WPA2 option for security as your hub should be on by default at the minute to see if this helps?
To make this change, go to advanced settings>wireless>security and opt for WPA protocol instead of the WPA2 one.
Once you save this, see if refreshing the Wi Fi connection with your speaker works this time.
Lastly, could you please tell us what error you get when attempting to connect your Sonos to the Wi Fi so we can advise more?
Please, share these and we're here to assist further where needed.
on 30-06-2023 10:29
Hi Adri. Thanks for replying and sorry for the delayed response, I have been away with work.
In the meantime we were upgraded to a Hub 5 but unfortunately we are still having issues with Sonos.
The Sonos now connects to the WiFi but we can't use Alexa to play music (through any player: Amazon Music, Spotify, etc).
The router settings are as per above - ie we have given 2.5 & 5 GHz separate names.
I have also followed your advice by switching off smart Wi-Fi however a) this didn't resolve the issue, and b) it meant that other devices (eg my TV) couldn't connect to either 2.5 or 5.
Also I am unable to switch from WPA-2 to WPA as there is no option for this. The available options are WPA2-PSK, WPA3-SAE, or WPA2-PSK/WPA3-SAE.
Would really appreciate more help. Thanks.
on 30-06-2023 11:11
The Hub 5 is has the newer wifi 6 AX protocol, so some older IoT can cause problems. Check as below and set the 2.4Ghz to legacy;
Access your Hub by navigating to 192.168.0.1
Login with the default login info (on base of Hub) unless you've already updated it.
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
If all fails, you could try a basic 2.4Ghz wifi extender, connect this to the Hub and connect the Sonos to the basic extender.? Something like this Buy TP Link 300Mbps Universal Wi-Fi Range Extender | Wi-Fi boosters | Argos
