urban_spaceman's avatar
3 years ago
Connecting Sonos to Virgin broadband
Hi there. Am really hoping someone can help me!!!
We have recently moved home and had Virgin Media broadband installed with the “Hub 3”.
However my Sonos is not connecting to it.
The Sonos app is saying that if a router supports both 2.5Ghz and 5Ghz then they need to be split and renamed. I've tried this - I think - by going into the router settings then into Wireless then security and giving both different names. No joy.
One at a time I have also disabled each and tried, but again no joy.
Can anyone help at all please?
Thanks a million.
  • Hi Rob. I believe that most of this is covered in the previous 2 pages - of which you're the third Forum Team member contributing - which is quite frustrating.
    • Daniel_Et's avatar
      Daniel_Et
      Hi urban_spaceman, we're sorry to hear you feel this way 😔
      Have you tried contacting the Gadget Rescue team about this matter? Information on how to do so can be found here.
      Regards,
      Daniel
    • David78's avatar
      David78
      Hello Spaceman,
      OK, as of about 10 minutes ago I have a fix but it does involve connecting a 'mesh' network.
      Before I switched to Hub5 on Monday this week my Sonos had been connected to a Google mesh/extender network which was fed via a VM Hub3. If this means nothing to you, let me know and I'm happy to explain in detail, it's quite simple. I have had the Google mesh network for years for the sole reason of better extending the wifi around my house. Unbeknown to me the improved stability of the Google product was what kept my Sonos working where the VM Hub3 MIGHT not have.
      Upon receipt of the Hub5 I ditched the Google extension as the Hub5 got the wifi around my house better than the extension.
      Trying to connect to Sonos reliably to the Hub5 seemed impossible (and might be). I tried factory resets, ethernet cables, every router setting and no joy.
      I therefore decided to revert to the prior setup of Google mesh network connected into the Hub5 and revert to that set up for Sonos.
      My expectation is that if you repeat the above, yours should work. However, this is where life got really complicated for me because reverting to my previous set up also failed to work! I am explaining this because it threw up another issue which may be relevant to you and is certainly worthy of this public forum.
      The Sonos rep that I spoke to this evening, by pure luck, had previously picked up on an issue that Sonos does not list nor admit to, which is that many Google Pixel phones are unable to set up Sonos systems! I use a Google Pixel 6 and he advised my to try with my wife's phone... 5 minutes later everything worked seamlessly.
      10 minutes in now and it's still working 🤞
  • Same issue here, Hub3 did not even consider the router would not work with Sonos units....
    I've tried all the setting changes as advised, after swapping to Virgin are we expected to buy 3rd party kit to make things work? my BT router did the job fine
    • Jodi_S's avatar
      Jodi_S
      Hi Scratch123,
      A warm welcome and thanks for posting on our community forums. We're sorry to hear that you too are having issues connecting your Sonos to your hub.
      We appreciate you trying all the diagnostics i this thread. If your device is not connecting, our Gadget rescue team What is Gadget Rescue | Virgin Media Help may be able to assist your further with this issue as we are limited to what advise and help we can offer on 3rd party equipment.
      Kind regards Jodi.
      • David78's avatar
        David78
        I would be very wary about paying VM for 'Gadget Rescue'. In my opinion they will not be able to help as the devices are not compatible. Furthermore there will be little cost difference between this and adding a third party product to the router.
    • jimmyt111's avatar
      jimmyt111
      I’ve spent roughly 4 hours this Sunday evening trying all of the steps suggested in this post to connect my Hub 3 to a Sonos One. Before giving in I tried one further step and that was to connect the Sonos via an Ethernet cable and running a software update. After removing the Ethernet cable I was finally able to connect wirelessly to my 2.4GHz Network.
      • Tom_W1's avatar
        Tom_W1
        Hi jimmyt111 thanks for your post here - we're glad you were able to get this resolved!
        We appreciate your contribution and hopefully this does help other users in the future.
        Many thanks
  • Just an fyi. We just switched to VM broadband and had the same issue getting the Sonos to set up wirelessly. Switched 5ghz off, reset the Sonos, reset the app to start with a clean slate etc etc and i could not get it to connect with my phone.
    Seen a post a few back about Pixel devices (i have a Pixel 6 pro) so tried setting up with my wifes Samsung... And it worked! Didn't connect at the first attempt after putting the new network details in - but second attempt connected in a few seconds.
    That's about 4 hours of my life i'll never get back. Hope it helps though.
    • ScottyF791's avatar
      ScottyF791
      PS - went in via the support option in the settings menu on the Sonos app to find the Play 3 rather than clicking on the "lets fix it" prompt.
  • AB1918's avatar
    AB1918
    I have had exactly the same problem with drop-outs, the constant variable attempts to sort-out the system as listed in all the previous replies and the blame culture between Sonos and Virgin. I have spent hours of my life that I'll never get back on this. The latest solution is a decent router and use the Virgin Hub as a modem. Thoughts on this would be appreciated.
  • had same problem with sonos 1 trying to connect to hub 5 , i done a factory reset on the sonos and then it connected no problem
  • AB1918, my personal experience is that your suggestion is the only way of running Sonos with Virgin Media. I have tried everything else with no joy. I use a Google Mesh Wifi Noad, plug and play with the VM hub, no need to change settings and it works seamlessly. Other advantages are 1) that you can add noads to better the signal around your house. 2) Connect all of your devices to this rather than the VM hub. When you inevitably switch from VM to Sky or BT you will simply connect the noad to your new suppliers hub and all of your devices will reconnect. Same goes for moving house.
  • UBVL's avatar
    UBVL
    Hi All, I had the same problem. Joined VM broadband a few days ago, have hub5 and Sonos stopped working due to connection issue and got similar message as urban_spaceman.
    Then I stumbled on this message trail on google and the initial few messages were all Greek and Latin for me (splitting, WPS2/WPS, mesh WiFi etc) and I just kept reading replies until I read RoyRodgers message of doing factory resetting on Sonos, which I thought is easy and I could do it, which I did….AND IT WORKED!! saved me hours of headaches. I could connect straight away and it said my Sonos beam needs software upgrade which I did.
    probably worth for everyone to first try factory resetting of Sonos products before trying other things on VM products
  • Hi, did you find out what the issue was and how you rectified it? I've just moved to Virgin and can't connect my Sonos. I've followed all the advice in this thread and have had no luck. Any advice on what you tried or how it work for you would be appreciated
      Hi mikestuart84
      Are you, using any other 3rd party equipment such as VM Wifi pods?
      Info below mainly related to VM WiFi Pods from the FAQ's on  /virginmedia.com/help/how-to/broadband/wifi-pods
      Sonos speakers should be kept at least three feet away from the WiFi Pods (white) – and other devices. You should also check that your speakers are up to date with the latest firmware.
      You must only connect one Sonos speaker, Connect, or Boost to your Pod with an Ethernet cable. The Sonos system should then create its own network using your home WiFi.
      • mikestuart84's avatar
        mikestuart84
        Hi, thanks for replying. I've just got the Hub 5 and nothing else. Following all the steps but they just can't find the WiFi even when cabled to it. I've changed all the settings on my hub as explained in this chat but none worked.
