Ruthyb121's avatar
Ruthyb121
BROWN PLASTIC BOX HOLDING WIRES THATS OUTSIDE IS BROKEN
Hi everyone
I noticed that the brown plastix box outside my property, that houses VM connections, is broken and some wires are coming out of the bottom of the box.
Im worried that this may pose a problem because of inclement weather and also the fact that someone may try and vandalise this (as has happened in this area before with an electric box that wasnot secured properly)
Im a new customer and I cant help but think that this should have been properly closed after initial engineer visit last month.
Is there a way to repair this? Can VM rectify this?
Thanks for any advice.
  • Tudor's avatar
  • Akua_A's avatar
    Akua_A
    Hi Ruthyb121
    Welcome to our community forums and thank you for raising this brown box with us. We can understand the concern caused, especially as a new customer, and we want to best help. To best look into this, we are sending you a private message. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
