simeong
1 year agoJoining in
Home phone not working since voip switch,
We recently found out that our homephone has not worked since the copper switch.
It is connected to the hub5 as directed but when you call the number it gives a unable to connect message and dialing any number from the phone gives an engaged tone. I thought it was possible the phones at fault (they're quite old bt cordless ) so bought new hub router compatible ones but still no joy.
Is there anything else I can do before I negotiate the nightmare that is the VM call centre!!
Simeon
