Bid1's avatar
Bid1
Dialled in
Virgin ultra HD and TNT sports Ultimate
Hi all
on virgin stream,  virgin ultra hd and tnt sports ultimate isn’t broadcast in 4k on virgin stream.
when I select tnt sports ultimate it’s changes my picture to HLG.
  • HLG only comes with UHD broadcasts and it's reasonable to believe that UHD also only comes with UHD streams. As you have HLG I believe you are getting UHD streams from TNT Sports Ultimate.
  • Roger_Gooner's avatar
    Roger_Gooner
    If a stream like TNT Sport Ultimate has HDR, as it does for broadcast channel, it will be HLG.
    Hi Bid1
    The picture format may be due to your Stream box settings, or your actual TV settings.
    On the Stream box you need to have UHD set up under Settings > Audio & Video > HDMI resolution 4K.
    On my TV the TNT Sports Ultimate (CH 531) and the Sky Sports UHD channels on 532 to 535 are all  broadcast in 4K HLG HDR
    You need to pay extra for the Sky Sports UHD channels, however the TNT Sports Ultimate channel is included in the TNT subscription price.
    • Bid1's avatar
      Bid1
      Dialled in
      Thank you for your response.
      I get the hlg logo coming on the screen. But when you press info on the virgin remote control. It’s should info days HD and Dolby sounds sign next to it.
      • Carley_S's avatar
        Carley_S
        My apologies Bid1
        I'm not sure what you're advising in your latest post.
        Are you saying when you click on info, the information is wrong in some way?
    Roger_Gooner
