Mattybw76's avatar
Mattybw76
TNT ultimate No Audio
Hi all,
Has anyone having issues with audio on TNT ultimate, I have no audio at all, picture is prefect but no sound. I notice a number of issues with TNT ultimate sport over last couple of weeks. With the channel being suck and now this. Works perfectly on TNT sports 1 though!?
    • Tardis446's avatar
      Tardis446
      Same problem here! I’ve never watched a game all the way through without sound failure. Always end up switching back to TNT Sports 1. Whenever I run checks it finds problems and says it can’t help at the moment, come back in half an hour???
  • Adri_G's avatar
    Adri_G
    Hi, Mattybw76.
    Thank you for reaching our on our help forums and for joining our community recently 🙂
    We're sorry to hear there's no sound when watching TNT Sports Ultimate specifically on your TV box, this is not the great experience we aim to provide.
    We'd love to help out, if there's no known outage (TV-related) in your area showing here to explain this issue, then it may be down to a device issue or other.
    To confirm this, do you experience sound issues with any other channel at all?
    Also, how long has this sound problem been on for and do you get the sound when you try watching TNT Sports Ultimate via a browser here or our VM TV Go App?
    Just to rule out a few standard scenarios can you please kindly check and follow the below steps:
    To access and check audio settings, first press 'Home' on your Virgin TV remote to reach the main menu.
    Follow these steps to get the correct settings. Choose Help & Settings > Settings > Audio & Video > Dolby Digital and disable 'Dolby Digital'.
    Try disconnecting all other devices connecting to the TV box (if any), leaving just the TV box to see whether it works.
    Reboot TV box, check all cables and connections are firm and try the channel again.
    Let us know how things go from here and if you need more help, glad to support you in the best way we can. 🙂
    • Mattybw76's avatar
      Mattybw76
      Hi Andr_G
      It seems this was not a single unrelated issue, see above penntangu’s comment, they also had the same problem. Please can you investigate why these errors are happening with your streaming service.
      I have done everything as per instructions which come with the device. The streaming box is hardwired directly to the internet and everything is working fine.
      As pointed, I have experienced this channel being suck on (freezed picture) and no audio issues as well. This seems to be a larger problem than just one streaming box issue.
      I await your internal findings on this, maybe your monitoring systems didn’t pick out this outage as I have stated the picture was fine but no audio.
      regards
      • Daniel_Et's avatar
        Daniel_Et
        Hi Mattybw76, thank you for your response.
        In order to look into this for you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
        Regards,
        Daniel
      Daniel_Et
      Hi Simon1111, thank you for your post.
      Regards,
      Daniel
      • Matt761's avatar
        Matt761
        Same issue using virgin stream box. No sound only on tnt ultimate, every other channel fine. I've tried unplugging other devices, changing hdmi cables and ports, changing sound settings. Nothing works. Can an admin message me to resolve as virgin stream box seems to have no technical support.
  • I'm having this same issue on my stream box. Trying to watch football in TNT Ultimate but there is no sound!
    • Alex_RM's avatar
      Alex_RM
      Hi tstabor90,
      Thanks for posting and welcome to our community 🙂
      Sorry to hear you've been having some issue with TNT Sports, has there been any change since your post on Tuesday?
      Have you rebooted your equipment?
      Alex_Rm
    • MickeyJMay's avatar
      MickeyJMay
      Same again today on my VM Streambox, no audio on TNT Sport Ultimate. Sound ok on TNT Sport 1.
  • Hi
    Im having exactly the same issue in my stream box hd1 works fine but no audio on ultimate.
    Anyone had any joy yet?
  • I am also experiencing this problem. I have done a complete reboot of the device.
    • Nuvoman's avatar
      Nuvoman
      Same issue, Panasonic tv so it’s not the tv. No volume on ultimate.
  • The_Red_Silence's avatar
    The_Red_Silence
    I'm getting TNT with Ultimate soon so I'd very much like yo know whether this issue has been rectified if not. Clearly it's nothing to do with the end user settings or experience.
    • Gareth_L's avatar
      Gareth_L
      Hello The_Red_Silence.
      Thanks for your post.
      When you do subscribe to TNT ultimate, Can you please let us know if you experience any audio break up.
      That way we will be able to take a look at this in more depth for you.
      Gareth_L
