glennhi's avatar
glennhi
3 months ago
Stream Remote Volume control with Xgimi Projector
Wondering if anyone knows of a code to get the stream remote volume control working with an xgimi projector? I suspect it isn't possible as the brand isn't listed.  Maybe someone has found an alternative code that may work?
  • Hi glennhi,
    The Virgin Media Stream remote can control the volume of most TVs, including projectors, as long as the TV is connected to the Stream box. However, there may be compatibility issues with specific projectors, such as XGIMI, which might not be fully supported. If you encounter difficulties, ensure that your TV box and remote are properly connected and configured.
    If you go to this link it could help Need help with a Virgin TV remote problem? | Virgin Media Help
    Or our helpful community members will be here to help with anything we can't offer support with 🙂
    A  quick google search shows "In order to have better sound quality in home entertainment with projectors, XGIMI and Harman Kardon have established a close partnership since 2015. As the only partner of Harman Kardon in the projection industry, XGIMI has successively launched a variety of home projectors equipped with Harman Kardon original audio, such as the familiar HORIZON series and the XGIMI laser projectors AURA series."
    I doubt you'll ne able to pair it as a speaker so I suggest try pairing with Harman Kardon under the TV set up option on the Stream box first of all.  As a last resort if that fails then try Samsung since Harman Kardon are a subsidiary of Samsung.
