gareth_trott's avatar
gareth_trott
replacement stream box power block
Is it possible to get a replacement power block for the virgin stream box? When we had ours installed the engineer plugged the box straight into the TV and connected the box to our WiFi. Now a little way down the road I would rather have a wired connection but I can not find the power supply that also has the ethernet port.
I am actually not sure the engineer left us with the original kit, unfortunately I was not in when they visited. My family at least have no idea where it might have ended up if we do have it.
  • Reece_MH's avatar
    Reece_MH
    Hi gareth_trott 👋
    Thanks for posting, and a warm welcome back to the Forums.
    I'm sorry to hear you're missing your power supply unit for your Stream box. I'm going to send you a private message, so we can look into ordering this for you.
    Please look out for my message in the top-right, white envelope or by tapping your profile picture and then "Messages".
      • John_GS's avatar
        John_GS
        Hi b33v3r
        Best wishes.
