doddsy112's avatar
doddsy112
Wireless being faster than wired on ps5
Hi, does anybody know why my internet connection is faster through wireless than it is wired when connected to the ps5? Currently connected to the router with a cat 8 Ethernet cable to the ps5, wired connection is download 91.9Mbps upload 9.1Mbps.
I’ve  completed different wireless tests around the house as well through the app. bedroom 1 download is 804Mbps where the ps5 is and upload is 100Mbps I’ve bought a second router as well to connect to and that was pulling full speed for a couple of days and that dropped as well to the same speeds while wired so disconnected it.
Thanks in advance
  • Megan_L's avatar
    Megan_L
    Hi Doddsy112,
    Thanks for posting this question on our Community Forums, I can see why you're a little perplexed at the speeds seen as wired connections are inherently faster than WIFI.
    Can I ask if you're using the PS5's own speed test function to view the speeds through the Ethernet? If yes, then this will be why you're seeing a lower speed - Console's speed tests are not a true reflection of the speed actually going through the cable.
    If you have a laptop you can plug the Ethernet in that will show a reliable speed. If you do this and it's still the same slow speed then please let us know!
    Megan
    • doddsy112's avatar
      doddsy112
      Yeah I do it through the ps5 “test connection” option, I have a pc as well and that’s hitting the top speed. So it’s more of a visual thing regarding the ps5?
        doddsy112
        It can’t be a visual thing on ps5 though because when I’m wireless it’s showing 400mbps down and 100mbps up
  • Sounds like your device is negotiating a speed of 10/100 instead of 1Gbps over ethernet.
  • jpeg1's avatar
    jpeg1
    As above, it's probably connecting at 100M instead of 1G.
