JuicyGoomba's avatar
JuicyGoomba
3 years ago
1gig, hub 5, unusable for online gaming, packet loss and latency issues
Hello,
I've been with Virgin for almost 4 years now, as they are unfortunately the only provider nearby that does high speed broadband.
I say unfortunately, because I have nothing but issues both with dropouts and online gameplay since joining Virgin. The Hub 3 and Hub 4 were both awful even in modem mode and contributed their fair share towards the issues. I've recently managed to get upgraded to the Hub 5, but aside from the dropouts being fixed, the issues with latency and packet loss continue.
Online gaming is virtually impossible now. Even when the latency is good, I get constant packet loss varying from 1%-5%. 1% is noticeable, especially on competitive games, and 5% is just a waste of time. I setup a BQM a couple of days ago along with the Hub 5, the connection seemed relatively stable for the first day outside of a single large latency spike, but the packet loss could still be seen. As the days have gone by, the packet loss has only increased in number and frequency, as has the latency issues.
My current network setup is as barebones as can be. I previously had the Hub 4 in modem mode, connected to a Nest Wifi router as it was noticeably more reliable for everything. I've since been trialing the Hub 5 as the only router, and all I have connected to it is 2x phones via wifi, 1x Fire Stick by ethernet, and 2x PCs by ethernet. In fairness to the Hub 5, it is actually capable of functioning as a decent router, and is comparable to the Nest Wifi in performance (likely helped by no longer using the god awful Intel Puma chip in the Hub 3/4).
I figured only having the Virgin router and a barebones setup would at least help with finding the issues here. The packet loss is just as bad as with the Hub 3/4, as is the latency spikes. As I said before, the only improvement so far is that I don't have dropouts as far as I can see. The Hub 4 in modem mode still required an almost daily power cycle to maintain some degree of stability.
I have shared the BQM below. I'm currently debating switching to BT's slow copper FTTC for the sake of making online gameplay usable. I play a lot of competitive shooters, and it is literally killing me. Even online coop games were unplayable with the Hub 4 due to the dropouts. My neighbour is 3 doors down connected to the same line, and he has all of the same issues.
I've tried all the usual fault reporting processes via the My Virgin area, but the whole process is as useless as it is frustrating.
I have also attached my logs from the router below as well, if that helps.
Spoiler
Upstream:
049600000435120QAM 641
143100000425120QAM 642
23660000041.55120QAM 643
330100000415120QAM 644
423600000415120QAM 645
0ATDMA0000
3ATDMA0000
4ATDMA0000
Spoiler
Downstream:
1330000000342QAM 25625
21380000006.943QAM 2561
31460000006.743QAM 2562
41540000006.443QAM 2563
51620000005.843QAM 2564
61700000005.643QAM 2565
71780000005.543QAM 2566
81860000005.543QAM 2567
91940000005.643QAM 2568
102020000005.343QAM 2569
112100000005.243QAM 25610
122180000004.342QAM 25611
132260000003.242QAM 25612
14234000000342QAM 25613
152420000002.842QAM 25614
162500000002.742QAM 25615
172580000002.742QAM 25616
182660000002.642QAM 25617
192740000002.642QAM 25618
202820000002.642QAM 25619
212900000002.742QAM 25620
222980000002.742QAM 25621
233060000002.742QAM 25622
243140000002.842QAM 25623
253220000002.942QAM 25624
263380000003.243QAM 25626
273460000003.143QAM 25627
283540000002.742QAM 25628
293620000002.442QAM 25629
303700000002.142QAM 25630
313780000001.942QAM 25631
1Locked42127050
2Locked4315220
3Locked4319470
4Locked4319120
5Locked4327700
6Locked436614124
7Locked4333600
8Locked4331490
9Locked4331230
10Locked4327180
11Locked4336170
12Locked4233700
13Locked4239670
14Locked4245250
15Locked4259270
16Locked4265810
17Locked4275390
18Locked4279130
19Locked4271870
20Locked4282660
21Locked42104880
22Locked42139100
23Locked42130190
24Locked42112730
25Locked42121520
26Locked43156910
27Locked43147510
28Locked42182800
29Locked42205810
30Locked42253150
31Locked42330290
Spoiler
Router network log for today:
13-03-2023 16:12:36warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 16:12:36noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 15:35:26noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 15:35:26warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 15:35:23errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 14:52:57warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 14:52:57noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:49:29noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:49:29warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:42:13warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:42:13noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:11:43warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:11:43noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:08:58noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 13:08:58warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 12:43:13warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 12:43:13noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 12:12:45noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 12:12:45warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 11:12:55noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 11:12:55warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 10:16:46noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 10:16:46warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 09:14:06noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 09:14:06warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 08:26:01warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 08:26:01noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 06:24:52warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 06:24:52noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 06:14:45warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 06:14:45noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-03-2023 05:08:19warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • JuicyGoomba's avatar
    JuicyGoomba
     Been with CityFibre for a month now after leaving BT (who I switched to from virgin).
    All I can say is full fibre is amazing. 12ms to London. 1gb down/up as well. £30/M.
    Oh and I have it on good authority that the north east Virgin exchange is close to breaking point, which is why it's so unusable for gaming. The packet loss situation for my neighbour is twice as bad as what mine was when I made this post. It's abysmal.
    According to various engineers, Virgin are refusing to maintain or repair the exchange. Good to know my £62 per month was going to the upkeep of services eh?
  • I assume that the power used by BT's ONT is around the same. It's unfortunate that these can't merely be powered by the Ethernet cable that plugs into the router to avoid using a plug.
