mizunooto's avatar
mizunooto
8 months ago
Wifi takes forever to start up
Every time I restart my Virgin Media Hub 4, it takes about 5 minutes to get the steady white light back. Then it takes a further 15 minutes to get a 5GHz wifi signal back. Until then, nothing.
I would chat to customer services, but chat doesn't work on my laptop. Still, YouFibre has just started operating here so they might be a better bet!
  • Tudor's avatar
    Why do you need to restart your hub? I cannot remember the last time I restarted mine, probably about 2 years ago.
    To keep the 5GHz Wi-Fi off a DFS channel, login to the VM Hub menu,
    in the Wi-Fi settings change the 5GHz band to Manual channel 36 or 44.
    Using channel 44 on our VM Hub the 5GHz band re-start promptly.
    The Hub is most likely using a DFS channel for the 5Ghz band.  That’s why there is a delay in broadcasting.  Any DFS channel has to, by law, check for any radar signals before starting.
    As for the general starting time, that’s about normal.
