nadimc345's avatar
nadimc345
How long does an upgrade take?
Hi Team,
I requested an upgrade to 1Gbps last week, and the confirmation stated April 29th as completion date, but the upgrade is yet to be done. How long does an upgrade usually take?
  • Hi nadimc345
    Are you still on the M200 speed tier as per << This post >> ?  If so, or if you only have a hub 2 or hub 3 then you won't get the speed upgrade until VM send out either a hub 4 or hub 5 (the one you receive will depend upon stock levels) Once you've got the new equipment and activated it then your new speeds will kick in.
    The speed upgrade is usually immediate if you have the right equipment and the regrade was processed over the phone.
    If though you processed the regrade online via My Virgin Media, or via text message, online chat or whatsapp then it may take up to 14 days. Those regrades are processed manually by a back office team and they have a backlog at present.
    Should be immediate when VM has done their end.  You could try a reboot to get the new config fille loaded.
    Check the conf settings on the Hub. It will show what speed has been provisioned.
    It's Configuration tab - Primary Downstream Service Flow - Max Traffic Rate.
    Hi nadimc345
    • nadimc345's avatar
      nadimc345
      Thanks for the reply. I checked another community member's post and he mentioned he had contacted the support team via WhatsApp, which was a great idea! So I did the same thing and the agent I chatted with mentioned there was no upgrade request (although I had received the confirmation email with the new contract), and he placed a new order, confirming a new Hub 5 would be required. Waiting for the new hub to arrive so I can enjoy the 1Gbps speed!
      Thanks!
  • plums1234's avatar
    plums1234
    I did an online upgrade and also had completion date of 29th April and still nothing, I already have the Hub 5.
      nadimc345
      It's honestly been a bad experience with their ordering system. The first time I contacted them, they mentioned they never received the order, despite me receiving a confirmation email with the new contract. The second time, no delivery on the promised date, so I contacted their support team again via WhatsApp. The agent I chatted with mentioned they were out of stock and should be able to deliver the new Hub5 by May 7th, but I had a trip planned on that date.
      I had to eventually cancel the upgrade for now. Quite a disappointing experience.
        plums1234
        First agent I spoke to said I hadn't placed any order and refused to listen to the order number from the new contract
        She then said if I did it won't go live until day 15, day after cooling off period!
        I then tried online chat, he found the order and new contract but also said 15 days! I asked to cancel and he said £504 please
        I called retentions today, got a better deal and was all activated while I was on the phone, she wouldn't go off until I had tested all the new add ons, Inc Netflix.
        Same company, same problem, 3 different "outcomes"
