HDB33264960's avatar
HDB33264960
Just joined
5 hours ago
WiFi Pod Overheating and making a Buzzing Noise
All,
Last night I smelt a burning smell but couldn’t find the source of it. This morning I heard a buzzing noise which I traced to my WiFi Pod. When i touched it, it was very hot to the touch. So i turned it off at the mains, left it for a while to cool down then turned it back on. It seemed ok for a while, no buzzing noise and not overly hot. But it has started to buzz again.
I did try the above again and also rebooting it, but it’s still overly warm and buzzing. Any suggestions please?
1 Reply
  • jpeg1's avatar
    jpeg1
    These are known to overheat and risk fires. Remove it and request a replacement. If it's one of the old white ones, insist on one of the newer black ones as a replacement. They are also a better specification.
