15tc's avatar
15tc
8 months ago
Hub seems to be overheating
Good morning
my Hub3 has a permanent red light for last few days. It is warm/hot to the touch.
I have done the reset and this made no difference. I have restarted likewise. I have logged into the hub and run the diagnostics but these are only for network - it tells me to check the temperature without giving me any indication that this is a physical check or a diagnostic on the same tool.
The hub is working which is good but I'm really worried about its overheating and it breaking. It has been in the same position for years , not in direct sun, and the house is not hot generally.
Please advise how I can get a new replacement hub sent/installed.
Thank you!
Catherine
  • Engineer came on Friday and installed a new hub. Thanks to Lee on here and Engineer Steve, great job. !
    In the Hub 3 admin menu run the "Network diagnostic tool" again.
    When you see the results scroll down to the section:  Temperature is it Normal
  • Hi 15tc thanks for posting and welcome back to our community.
    Sorry to hear of the constant red light on your hub. And for any concerns this may be giving you. So that I can take a look on your behalf, I'm going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
    Lee_R
    Irrespective of the actual current temperature, this red LED is the overheat warning and should be working correctly.  It's too much of a risk to leave it, just in case ...
