Geezertronic
4 months agoTuning in
WiFi pod not working
I have been sent one of the crème coloured WiFi pods which the limited instructions say to plug on, give it 10 mins, and it should work. The light on mine keeps flashing and the VM Connect app says it is offline. I tried relocating the pod to within a couple of metres away from the router just to see if it would connect but it still doesn’t work. I also tried to remove and re-add it via the VM Connect app but it wont re-add.
There seems to be limited support for getting these working, would anyone know where I could look next please?
