northerner
1 year agoJoining in
WiFi Pod Activation Issue
Hi there
After some help with the (black) WiFi pod that I was recently sent. Unfortunately I constantly get an ‘activation failed’ in the VM connect app.
After raising the issue on the on the live chat, someone called me back to say because I was using a switch into the back of the hub (this is to give me more LAN ports) it wouldn’t connect.
Anyway, I have since disconnected that and tried again, but same issue. When I run the self check it’s not telling me my hub needs a factory reset. Before I do that, is there anything else worth trying?
Thanks!
