Predawncoot84's avatar
Predawncoot84
Just joined
WiFi keeps dropping out, T2/3/4 dropouts
WiFi keeps dropping out very frequently and for quite a while. Happens maybe every 10 minutes, 3 different engineers have come round to attempt to fix the problem and to no avail.
Ive seen quite a few people have success posting their network log here so I’m doing the same hoping something can be solved, and if it can that would be really appreciated
3.0 Downstream channels
Channel Frequency (Hz) Power (dBmV) SNR (dB) Modulation
13060000008.141QAM 256
21380000009.139QAM 256
3146000000941QAM 256
4154000000941QAM 256
51620000008.641QAM 256
61700000008.641QAM 256
71780000008.640QAM 256
81860000008.840QAM 256
9194000000941QAM 256
102020000008.840QAM 256
112100000008.840QAM 256
122180000008.741QAM 256
132260000008.741QAM 256
142340000008.640QAM 256
152420000008.440QAM 256
162500000008.341QAM 256
172580000008.341QAM 256
182660000008.241QAM 256
192740000008.141QAM 256
202820000008.141QAM 256
212900000008.240QAM 256
222980000008.239QAM 256
233140000007.941QAM 256
243220000008.241QAM 256
253300000008.141QAM 256
263380000008.141QAM 256
273460000007.741QAM 256
283540000007.640QAM 256
293620000007.641QAM 256
303700000007.740QAM 256
313780000007.840QAM 256
323860000007.741QAM 256
  • 3.0 Upstream channels
    06030000043.55120QAM 649
    153700000445120QAM 6410
    24620000043.55120QAM 6411
    339400000445120QAM 6412
    432600000445120QAM 6413
    523600000445120QAM 6414
    • Predawncoot84's avatar
      Predawncoot84
      Just joined
      25-11-2024 23:57:38criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:57:38warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:57:38noticeREGISTRATION COMPLETE - Waiting for Operational status
      25-11-2024 23:57:28warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:57:22noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:57:21noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:57:15warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:57:13noticeHonoring MDD; IP provisioning mode = IPv4
      25-11-2024 23:56:58warningToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:56:56criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:53:40criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:48:21criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:48:21criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:48:21critical16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:47:41criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:47:41critical16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:44:21criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:37:09noticeGUI Login Status - Login Success from LAN interface
      25-11-2024 23:35:00noticeGUI Login Status - Login Fail from LAN interface
      25-11-2024 23:31:28noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 18 19 20 21 23 24 25 26 27 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:31:13noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 18 19 20 21 23 24 25 26 27 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:31:01warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:58noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 19 21 23 24 25 26 27 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:51noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 18 19 20 21 23 24 25 26 27 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:51warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:46warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:42noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 18 19 20 21 23 24 25 26 27 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:34warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:30:15noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 18 19 20 21 23 24 25 26 27 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:29:55noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:29:28criticalNo Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:29:28noticeREGISTRATION COMPLETE - Waiting for Operational status
      25-11-2024 23:29:28warningTCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      25-11-2024 23:29:20warningDynamic Range Window violation
      25-11-2024 19:59:31noticeGUI Login Status - Login Success from LAN interface
      25-11-2024 19:17:40noticeGUI Login Status - Login Success from LAN interface
      25-11-2024 19:17:00noticeGUI Login Status - Login Fail from LAN interface
      25-11-2024 17:12:10noticeGUI Login Status - Login Fail from LAN interface
      25-11-2024 17:05:29noticeGUI Login Status - Login Success from LAN interface
      • Vikki_M's avatar
        Vikki_M
        Hi there,
        I'm sorry to hear about the brodband issues you're having.
        I'll send you a private message now so I can help.
        Please look out for the envelope in the top right of the page and pop back to me when you can.
