WeeJDoh's avatar
WeeJDoh
WiFi connection dropping
Hoping someone can help. I have the Gig1 broadband, and speeds are really good in most of the house. However in my bedroom and the upstairs office, I keep having the connection drop, which isn't ideal when I'm trying to work. I've used the app to test speeds - sometimes it's fine, other times it can't pick up a signal and just tells me to try again later.
This has been going on for the best part of a year, I can't get through to support - it just takes me in circles back to FAQs, and because when the app does pick up the good signal, it's obviously saying I don't need a pod to help with it. I am now at a complete loss and don't know where to turn. Any advice would be gratefully received.
  • Daniel_Et's avatar
    Daniel_Et
    Hi WeeJDoh, thank you for your post.
    We're sorry to hear about the problem you're experiencing and that you feel this way ๐Ÿ˜”
    In order to discuss this further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Thank you for your support Client62 ๐Ÿ‘
    Regards,
    Daniel
    Add Wireless Access Points or Wi-Fi Repeaters to extend the Wi-Fi signal to the bedroom & upstairs office.
