Hayleycropper's avatar
Hayleycropper
Wifi booster..
Having real issues with my boosters. So I live in a small two up two down. If I leaned over the banister I could see our router the house is that small.  Router speed is 250mb. We have a booster in the kitchen and upstairs hallway (we did live in a big house) I’m currently in the spare bedroom with a booster literally outside my door and I’m pulling 11mbps with 1 bar on wifi. Router was rebooted yesterday (by accident) and the pods have been rebooted just now. No improvement. They’re the newish model I believe. White weird shaped one. I read on another post that resetting the device using the reset pin hole might help? Any ideas? Again. Virgin are useless and I work for IT. I’m not stupid when it comes to network but they talk to me like I am.
  • John_GS's avatar
    John_GS
    Hi Hayleycropper
    Thanks for coming back to the thread.
    There are a few requirements for the Pods to work with our Hubs:
    •    The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'.
    •    Channel Optimisation must be left on.
    •    The SSIDs must be the same and broadcast enabled.
    •    The SSID must be password protected.
    •    The Passphrases of the SSIDs must match.
    As long as all of the above points are all met then the Pod should automatically connect to your Hub's Wi-Fi and begin broadcasting. The wireless details from the Pod will be the same as the Hub's details, so no additional steps are required to connect the devices in the home.
    Please also ensure that the Pods are not in the direct area where any coverage blackspot exists. They need to be placed mid-range from where the router is, to the area where you're having the issue. Best wishes.
  • Ayisha_B's avatar
    Ayisha_B
    Hi Hayleycropper 👋
    Welcome to our Community Forums and thanks for your post.
    Sorry you're having some issues with your WiFi Pod.
    Have you had a look at our troubleshooting guide 👉 here for further support?
    Just a punt as you don't mention the type of VM Hub that is involved.
    VM Pods & VM Connect app can stop working with a Hub 4 that has admin menu failure.
    • Hayleycropper's avatar
      Hayleycropper
      Think it is is hub 4 but no settings have been changed from default. I’ve ordered a new one as we did move house with the 2 boosters. Possibly not connected apparently. We’ll see if the new boosters work. If not. Back to the drawing board
      • John_GS's avatar
        John_GS
        Hi Hayleycropper
