Set123456's avatar
Set123456
VM connect cant find hub 4
My VM connect app can't find my hub 4. I've tried all the tips in the community e.g. resetting the hub, deleting and re-loading the app etc but nothing is working.
I want it to help manage screen time for my son so I can disconnect wifi to certain devices.
  • Sephiroth's avatar
    Sephiroth
    The one tip you didn't try (but I can understand why), is to abandon the wretched CONNECT app.  Your best hope in present circumstances is that VM swap the Hub 4 for a Hub 5 which, according to reports, is seen by the wretched CONNECT app.
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there Set123456
    I am so sorry to hear that you have faced this issue with the connect app! Can I ask if you have tried to uninstall and reinstall the app at all? I know it seems a little basic but it can help to reconnect the app.
    Can I also ask if you have been able to try the app on another device?
