Jackwelch86's avatar
Jackwelch86
Just joined
Top WiFi light blinking uncontrollably
Hi there.
I have a super hub 3, wired it’s fine but wireless it drops sometimes in the day and the hubs WiFi top light flashes green uncontrollably for about 2 minutes then goes back to normal, the hub does not restart or anything and it’s super weird, makes me think it’s the hub as the wired connection works fine.
any ideas?
  • Hi Jackwelch86,
    Thank you for your post and welcome to the community.
    I'm very sorry to hear about the issues you've had with your Wireless connection.
    Can you confirm if you are still having this issue?
    ^Martin
  • jbrennand's avatar
    Well if ethernet connections are all good then either there is a problem in the Hub's wifi "circuitry" - or you have some wifi inerference.  Do wifi connections drop on all of your devices at the same times?
    Is there anything unusual showing in the Hub's network logs?
