looper's avatar
looper
tired of hub5 keep dropping
been a virgin client for over 10 years never had issue like now with hub5 net keep dropping every other min this is bad as hell i will hope for someone to contact me and sort this out of give me back my older router much better than hub5.
  • Nothing wrong with a functioning HUB 5.
    Sounds like you have a faulty one.
  • RT123's avatar
    RT123
    Up to speed
    The Hub 5 it is probably not the fault here - could you please provide the upstream, downstream and network logs from 192.168.0.1 (or 192.168.100.1 if in modern mode)
  • Tudor's avatar
    The Hub4 and Hub5 use more frequencies on the cable than a Hub2 or Hub3. Most problems like this are down to a circuit fault. So please post some stats, details follow:
    How to get stats from a VM hub (no need to logon to the hub)
    Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
    • Click on the “> Check router status” button
    • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
    • Click on the “Upstream” tab, copy the text and paste into your reply
    • Click on the “Networking” tab, copy the text and paste into your reply.
      • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there looper
    I am so sorry to hear that you have faced these issues with your service and thank you so much again for posting.
    Can I ask if you have the Hub in modem mode?
