designerphill's avatar
designerphill
4 months ago
Solid redline on my hub3
Hi just out of nowhere my router has stopped working with only a solid red line from what I have read it’s over heating however it doesn’t feel hot to the touch I did however turn it of for 15 mins with no change so i did factory reset still nothing it come back online for 1 min then back to nothing how do I go about swooping it out for a replacement? Cheers phill
  • jbrennand's avatar
    As it isnt working - just call it in on the fault line on 150 (VM Phone - free) or 0345 454 1111 (any other phone - national rate). Use option 2 (faults), dont press any other buttons when offered and you should be in the queue for the next agent.
  • Hi designerphill 👋 Welcome to the community forum! Thanks for posting.
    Sorry to hear about the connection issues! You can check for any outage showing as affecting you 👉 https://virg.in/service or by calling 📞 0800 561 0061? Let us know if there is nothing showing! - We can then offer further help if still needed.
    Thanks for your patience in the meantime! 🌞
