baldiepete's avatar
baldiepete
3 months ago
Solid red LED on Hub 3.0
I have a hub 3.0 which is showing a solid red LED. Looking this up online indicates the Hub is overheating. It’s warm on top but I wouldn’t say it’s hot. It sits on an open shelf, out of the sunlight with space on either side. The hub is in router mode.
Following the advice on the website I’ve switched it off for 20 minutes but the LED stayed solid red after powering it back up. I’ve tried resetting it to factory settings with the same result.
Can someone from the Forum team please contact me to arrange a replacement hub. I am happy to install the hub myself without the need for a technician visit.
  • Tom_W1's avatar
    Tom_W1
    3 months ago
    Hi baldiepete thanks for posting although we're sorry to hear of your issues with your Hub 3 light.
    Please let me send you a PM so we can look into replacing this for you.
    Kindly respond directly when you can!
    Many thanks
  • I have had my hub 3.0 for nearly 3 years. Over the last 2 years it has had a constant red light. I do not believe it’s overheating but it’s still a worry. I called customer service 1 year ago and they did not help
    • Deepak_S's avatar
      Deepak_S
      Hi brooklyn1999,
      We are sorry to hear about the issues with your hub! This is something we can assist you with 🙂
      Please first look out for a private message from us.
  • baldiepete's avatar
    baldiepete
    Problem resolved. I got a new hub installed only a couple of days after raising the problem here.
    baldiepete
    I meant to post this in the Networking & WiFi board but somehow it ended up here! I suppose now that my landline phone connects to the hub it’s still an appropriate place for it. Hopefully a mod will see it soon.
    • Tom_W1's avatar
      Tom_W1
      Many thanks
    If it is a Hub 3 and if the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly.
    If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
