SweetFA
1 year agoOn our wavelength
Hub 3 solid red light.
Hello Virgins. ✌🏼
As the title suggests! The light at the front has a solid red light instead of the solid white.
This hasn't changed after a reboot and a reset. 🤷🏼♂️
My understanding is that a new hub is needed 🙄
I look forward to hearing from VM.
Many thanks. 👍🏼
Hi SweetFA, thank you for your post.
We're sorry to hear about the problem you're having 😔
In order to discuss this with you, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
