- Client62Alessandro Volta
If you have a coax cable connected Hub 5, try restarting the Hub 5.
- ljohn1974Joining in
Don’t have a coax cable unfortunately
- carl_pearceSuperstar
Hub 5x?
Did you or an engineer previously split the SSID (Network) into two so devices that prefer 2.4Ghz could connect?
Maybe a hub update has reset it back to one SSID.
Not sure tbh. We only use apple products & they’ve connected ok previously but for the past week we can’t get anything to connect to the WiFi
Has the VM Hub started to display different front panel lights to usual ?
No still the same colour as it’s always been
- Nathan_B
Hi there ljohn1974 😊 Welcome to the forum and thanks for your post.
Sorry to see you're having issues with these smart devices connecting to WiFi. As Client62 has suggested it may be worth checking to see if splitting the network connection. The instructions for it can be found 👉 https://community.virginmedia.com/discussions/Wireless/separate-wifi-network-for-electric-heaters/5594421
Let us know if this helps.
Nathan
Related Content
- 1 month ago
- 3 months ago
- 5 months ago
- 1 year ago
