- fizzFibre optic
Hub 5 uses a wider frequency range. I had problems when I went to 1gb which I did not have on 600mb on hub 3. Various members will advise what to show here to help diagnose or see what the problem could be.
- legacy1Alessandro Volta
go back to hub 3 and old speed
or get a better router with 1Gb ports put hub in modem mode
- Kath_P
Hi Aki93,
We're sorry to hear you're having an issue with your new, updated connection. Checking things here, there is no open fault affecting you in your area however we can see that your downstream channels are not optimal and neither are your upstream. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Related Content
- 6 months ago
- 3 months ago
- 11 months ago
- 9 months ago
- 1 year ago
