StevenFreeman's avatar
StevenFreeman
10 months ago
Red Light on Router
I have read with other people with the following issue and I have constant red light for the last few months and the top of the router is slightly warm. Tried rebooting andpin hole reset and still just red light. Its well venitlated and seems to work ok but do you think this will be a problem moving forward??
  • Hi StevenFreeman
    Thanks for posting and welcome to the community, also thanks for reporting the red light issue plus what you've tried to do.
    If this is a Hub 3 and the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
