Majmarkuk's avatar
Majmarkuk
Just joined
2 days ago
red light on media hub
A permanent red light is lit on my virgin media hub. Tried reset etc and no change. Ive spoken with chat and they just tell me to monitor it. Appears to be causing some intermittent wifi connection problems. Any help?
    Is this a Hub 3 ?
    If YES login to the Hub 3 admin menu and run the Network diagnostic tool
    Share a screen shot of the report for :  Temperature
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. It is a potential risk and as such should be managed as such.
