mbbryant1961's avatar
mbbryant1961
Red light on hub3
Hi VM team,
My hub has been showing a red light for a while. I have tried resetting,, turning off and disconnecting the leads then waiting for an hour before reconnecting the leads and turning on. All that happens is the hub goes through all the connection process showing green lights and then once connected the light turns red. The hub doesn't feel that hot tbh. WiFi is very poor around the house and the VM connect app keeps telling me I'm not at home so won't check anything. I think I need a new hub and a WiFi booster. I WFH and the poor WiFi signal is very frustrating as my video calls freeze and drop out.
1 Reply
  • Vikki_M's avatar
    Vikki_M
    Hi mbbryant1961
    Thank you for your post and welcome to our community.
    I'm sorry to hear there's a red light on the hub, and that you're having some issues with the WiFi.
    I'll send you a private message now to arrange a replacement.
    I can also help with the WiFi concerns.
    Please look out for the envelope in the top right of the page and pop back to me when you can.
