didger2007's avatar
didger2007
RED LIGHT on hub3
As title suggests, Hub3(router mode),has a permanent red light showing,although never had issues before,with hub in same ventilated location as normal.
Hub doesn't seem warm to touch,and internet fine at moment,though last couple of days has seen a drop in 2.4 WiFi speeds.
I have reset a few times and moved router about,but perusing past posts,I am concerned regards overheating?
Regards in Advance
  • Thanks for reaching out to us didger2007, and I'm sorry to hear of the red light on the Hub 3.0
    Check out the envelope in the top right hand corner for a private message from me.
    David_Bn
    • Hairyjam's avatar
      Hairyjam
      Hi. My red light is solid too. Internet still works though
      • didger2007's avatar
        didger2007
        As you can see,a member of the forum team reached out to me,and he actually arranged for an engineer visit to sort the issue
