Philkatie14's avatar
Philkatie14
Red light on hub
My virgin media hub has had a red light constantly on for over 6 months. I called the help desk a few weeks back who advised there was nothing they could do as we still had internet. Although we do have internet it is very temperamental and is constantly requiring restarts of the hub. I have tried every tech answer possible and the red light does not go. This is a Hub 3
  • Daniel_Et's avatar
    Daniel_Et
    Hi Philkatie14 👋 Thank you for your post and welcome to the Virgin Media Community 😀
    We're sorry to hear about the problem you've been having 😔
    In the first instance, please follow the below steps in the following order:
    • Turn the power switch off on the back of the Hub
    • Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
    • Use the power switch to turn the unit back on
    If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, it'll need replacing.
    Regards,
    Daniel
    • Philkatie14's avatar
      Philkatie14
      Hi I have tried that on multiple occasions and it still shows the red light
      • Lee_R's avatar
        Lee_R
        Thanks for getting back to us Philkatie14
        Sorry to hear of the ongoing issue you're having with the constant red light on your hub. And sorry for any concerns it may be causing you. I would like to take a closer look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
        Lee_R
