Mo160191's avatar
Mo160191
Red light on hub
My hub 3 has a red light and it's been like that for a few weeks. In the past week, my connection keeps dropping and this happens all day. The connection is really intermittent and it's a nightmare as my devices keeps buffering to state Internet connection lost or reconnecting.
Rebooted the router,reset it via the pin too and issue remains. Any help is appreciated.
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you
  • Hey Mo160191, thank you for reaching out and I am so sorry to hear this.
    Please do try these steps;
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
     I will send you a PM in meanwhile.
