CARRICK36's avatar
CARRICK36
Red light on hub
There is a red light on our hub. I have tried turning it on and off and a pin hole reset. Is there anything else I can do to rectify this?
Thanks very much.
  • Hi Carrick36 👋🏼.
    Thank you for posting, welcoming you onto the community forum 😊
    Sorry to see you have had a red light on your hub ☹.
    Thank you for trying the factory reset (pin hole reset), I can further investigate 🧐 for you and see what is is going on.
    I will have to private message you, please watch out for the envelope ✉.
